Ana içeriğe geç
PlayStation 5 Faceplates Replacement
Neye ihtiyacın var
  1. PlayStation 5 Faceplates Replacement, Remove the stand screw: adım 1, 1 resimden 1.
    • If your PlayStation 5 is in its vertical orientation, flip it upside down so the stand is facing up.
    • If your PlayStation 5 is in its horizontal orientation, skip to Step 6.
    • Work on a flat surface to prevent your PlayStation from falling over.
    • Use a coin or a flathead screwdriver to remove the 26.5 mm-long stand screw.
  2. PlayStation 5 Faceplates Replacement, Remove the vertical stand: adım 2, 2 resimden 1. PlayStation 5 Faceplates Replacement, Remove the vertical stand: adım 2, 2 resimden 2.
    • Lift straight up to remove the stand.
  3. PlayStation 5 Faceplates Replacement, Store the stand screw: adım 3, 2 resimden 1. PlayStation 5 Faceplates Replacement, Store the stand screw: adım 3, 2 resimden 2.
    • Insert the screw into the cubby on the bottom of the stand.
  4. PlayStation 5 Faceplates Replacement, Cap the screw hole: adım 4, 3 resimden 1. PlayStation 5 Faceplates Replacement, Cap the screw hole: adım 4, 3 resimden 2. PlayStation 5 Faceplates Replacement, Cap the screw hole: adım 4, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Use a pair of tweezers or your fingernail to remove the cap from the cubby.
    • Use your finger to press the cap into the screw hole.
  5. PlayStation 5 Faceplates Replacement, Close the cubby: adım 5, 3 resimden 1. PlayStation 5 Faceplates Replacement, Close the cubby: adım 5, 3 resimden 2. PlayStation 5 Faceplates Replacement, Close the cubby: adım 5, 3 resimden 3.
    • Twist the stand counterclockwise to close the cubby.
  6. PlayStation 5 Faceplates Replacement, Remove the horizontal stand: adım 6, 2 resimden 1. PlayStation 5 Faceplates Replacement, Remove the horizontal stand: adım 6, 2 resimden 2.
    • If your PlayStation 5 is in its horizontal orientation, rest it on its face with the charging port facing up.
    • Lift the stand straight up to remove it.
  7. PlayStation 5 Faceplates Replacement, Remove the left faceplate: adım 7, 3 resimden 1. PlayStation 5 Faceplates Replacement, Remove the left faceplate: adım 7, 3 resimden 2. PlayStation 5 Faceplates Replacement, Remove the left faceplate: adım 7, 3 resimden 3.
    • Lift up the corner of the faceplate with the PlayStation logo to unclip it from the case.
  8. PlayStation 5 Faceplates Replacement: adım 8, 2 resimden 1. PlayStation 5 Faceplates Replacement: adım 8, 2 resimden 2.
    • While lifting up the corner, slide the faceplate towards the bottom of the device.
    • Remove the left faceplate.
  9. PlayStation 5 Faceplates Replacement, Remove the right faceplate: adım 9, 3 resimden 1. PlayStation 5 Faceplates Replacement, Remove the right faceplate: adım 9, 3 resimden 2. PlayStation 5 Faceplates Replacement, Remove the right faceplate: adım 9, 3 resimden 3.
    • Flip the device over so that the USB and ethernet ports are on the left side from your perspective.
    • Lift up the corner of the faceplate to unclip it from the case.
  10. PlayStation 5 Faceplates Replacement: adım 10, 2 resimden 1. PlayStation 5 Faceplates Replacement: adım 10, 2 resimden 2.
    • Remove the right faceplate.
Sonuç
Repair didn’t go as planned? Try some basic troubleshooting, or ask our PlayStation 5 Answers community for help.
19 farklı kişi bu kılavuzu tamamladı.
Clay Kim
11.185 İtibar
21 adet Kılavuz yazıldı
1Rehber Yorum
Hello, thanks for the updates
hadi rp - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 27
Son 7 gün: 199
Son 30 gün: 1,241
Her zaman: 23,687
