Ana içeriğe geç
PlayStation 5 Slim Disc Drive Replacement
  1. PlayStation 5 Slim Disc Drive Replacement, Prepare your PlayStation for disassembly: adım 1, 3 resimden 1. PlayStation 5 Slim Disc Drive Replacement, Prepare your PlayStation for disassembly: adım 1, 3 resimden 2. PlayStation 5 Slim Disc Drive Replacement, Prepare your PlayStation for disassembly: adım 1, 3 resimden 3.
    • Before starting your repair:
    • Shut down your console and unplug all cables and accessories.
    • Remove any stands supporting your device and lay it down.
  2. Dikkatli ol: adım 2 yapım altında olarak işaretlenen bir kılavuzdan alınmıştır.
    PlayStation 5 Slim Disc Drive Replacement, Remove the disc drive cover: adım 2, 3 resimden 1. PlayStation 5 Slim Disc Drive Replacement, Remove the disc drive cover: adım 2, 3 resimden 2. PlayStation 5 Slim Disc Drive Replacement, Remove the disc drive cover: adım 2, 3 resimden 3.
    • The disc drive cover is secured with hooks along the back edge and clips along the front edge.
    • Firmly pull up the front edge of the disc drive cover to release the clips.
    • You'll hear distinct "pops" as the clips release.
    • Remove the cover.
    • To reinstall the cover, place the hooks into their cutouts along the rear edge and firmly press the front edge of the cover into place to re‑engage the three clips.
  3. Dikkatli ol: adım 3 yapım altında olarak işaretlenen bir kılavuzdan alınmıştır.
    PlayStation 5 Slim Disc Drive Replacement, Remove the disc drive: adım 3, 3 resimden 1. PlayStation 5 Slim Disc Drive Replacement, Remove the disc drive: adım 3, 3 resimden 2. PlayStation 5 Slim Disc Drive Replacement, Remove the disc drive: adım 3, 3 resimden 3.
    • Use the cutout on the bottom right corner of the disc drive to lift its right edge and disconnect it.
    • Remove the disc drive.
  4. PlayStation 5 Slim Disc Drive Replacement, Install the disc drive: adım 4, 3 resimden 1. PlayStation 5 Slim Disc Drive Replacement, Install the disc drive: adım 4, 3 resimden 2. PlayStation 5 Slim Disc Drive Replacement, Install the disc drive: adım 4, 3 resimden 3.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Spencer Day
96.225 İtibar
662 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
121 Üyeler
19.674 adet Kılavuz yazıldı
8Kılavuz Yorumları
Spencer, thank you for all your efforts in making this task manageable to all of us rtr novices!
Deeno
Deeno - Yanıt
once a disc drive has been paired with a system , can we use the same disc drive on another ps5 system ?
maniaque37 - Yanıt
Yes you can! You should be prompted to register the drive with your device, which will require an internet connection.
Spencer Day -
Where can I get a new disk drive in Australia?
Albert einstein - Yanıt
Also. Is it the same drive as you would add to the digital version
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 42
Son 7 gün: 219
Son 30 gün: 1,145
Her zaman: 12,159
