Ana içeriğe geç
PlayStation Move  Battery Replacement
Jenelle Mohammed
Jenelle Mohammed ve 13 diğer katkıda bulunanlar
En son September 18, 2024 tarihinde güncellendi
7 - 10 dakika
Orta
Daha İyi Resimler Gerekli
This guide will show the steps to dismantle the move controller and remove the battery in order to have it replaced.
Neye ihtiyacın var
Aletler
Daha fazlasını göster…
  1. PlayStation Move  Battery Replacement, Battery: adım 1, 3 resimden 1. PlayStation Move  Battery Replacement, Battery: adım 1, 3 resimden 2. PlayStation Move  Battery Replacement, Battery: adım 1, 3 resimden 3.
    • Using a Phillips #0 screwdriver, remove the four 10mm screws located on the back of the device.
  2. PlayStation Move  Battery Replacement: adım 2, 2 resimden 1. PlayStation Move  Battery Replacement: adım 2, 2 resimden 2.
    • Insert the plastic opening tool at the indent.
    • Gently use a forward and backward motion to safely pop open the cover.
    • Using your hands to further pull it apart.
  3. PlayStation Move  Battery Replacement: adım 3, 2 resimden 1. PlayStation Move  Battery Replacement: adım 3, 2 resimden 2.
    • Once the device is opened, lift the battery out of the black plastic holder.
    • Carefully pull the battery out and ensure that it's wires are still connected to the inside.
    You can disconnect the back/trigger assembly ribbon cable at this point by proceeding to Steps 13/14 (without the other steps for disassembly as they are unnecessary for replacing just the trigger).
    Peter Miller - Yanıt
  4. PlayStation Move  Battery Replacement: adım 4, 3 resimden 1. PlayStation Move  Battery Replacement: adım 4, 3 resimden 2. PlayStation Move  Battery Replacement: adım 4, 3 resimden 3.
    • Using a Phillips head screwdriver, remove the 9mm screw located to the right of the battery, which is connected to the inner plastic frame.
    • Using the plastic opening tool carefully take out the grey cylindrical piece (vibrator) that is also attached to a wire.
  5. PlayStation Move  Battery Replacement: adım 5, 2 resimden 1. PlayStation Move  Battery Replacement: adım 5, 2 resimden 2.
    • Gently pull out the small grey cylindrical piece (vibrator).
    • Removing this piece makes it easier to access the wire connection of the battery and remove it.
  6. PlayStation Move  Battery Replacement: adım 6, 2 resimden 1. PlayStation Move  Battery Replacement: adım 6, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Using tweezers, remove the small piece with a cylindrical top that is located to the left of the inner plastic frame.
  7. PlayStation Move  Battery Replacement: adım 7, 3 resimden 1. PlayStation Move  Battery Replacement: adım 7, 3 resimden 2. PlayStation Move  Battery Replacement: adım 7, 3 resimden 3.
    • Using one hand to hold the device, and the other hand to squeeze the inner plastic frame.
    • Remove by squeezing the inner plastic frame, lift and pull it towards you.
    • While removing the frame, be extremely careful because it could damage the frame or the motherboard.
  8. PlayStation Move  Battery Replacement: adım 8, 2 resimden 1. PlayStation Move  Battery Replacement: adım 8, 2 resimden 2.
    • Gently pull on the white piece connecting the battery and the connector.
Sonuç
9 farklı kişi bu kılavuzu tamamladı.
Jenelle Mohammed
229 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 3-3, Passmore Fall 2016 USF Tampa, Team 3-3, Passmore Fall 2016 üyesi
USFT-PASSMORE-F16S3G3
4 Üyeler
8 adet Kılavuz yazıldı
5Kılavuz Yorumları
When putting the plastic battery rig back in on my second time doing this, I bent one of the little plastic pins that fits into a hole in the PCB. Definitely want to be careful with that. To make it a bit easier, I unscrewed the bottom port PCB part of the way so I could take the bottom plastic housing and put the plastic battery rig in straight. It made it a lot easier.
Burke Cates - Yanıt
No need to take out the motor, just use sharp tweezers and grab the connector (NOT the wires) and with small wiggling pull it out. Worked for mine.
crus - Yanıt
Worked great! Thanks for this. I did not need to take out the black battery / motor piece. Tweezers worked great to remove and install the battery cable
Harry Skigis - Yanıt
Any recommended online / physical store to buy new batteries for this because ifixit doesn’t have them?
[deleted] - Yanıt
Je suis pas capable de coupler les manettes et quand j essaie de l ouvrir la lumière ne reste pas allumée. Sa se peut tu que les batteries sont finis. Je viens de l acheter usager
Rachelle Tremblay - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 14
Son 30 gün: 83
Her zaman: 15,428
