Ana içeriğe geç
PlayStation Move USB Port Replacement
Neye ihtiyacın var
  1. PlayStation Move USB Port Replacement, Case: adım 1, 2 resimden 1. PlayStation Move USB Port Replacement, Case: adım 1, 2 resimden 2.
    • Turn the controller over and unscrew the four 10mm screws with a PH #00 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  2. PlayStation Move USB Port Replacement: adım 2, 3 resimden 1. PlayStation Move USB Port Replacement: adım 2, 3 resimden 2. PlayStation Move USB Port Replacement: adım 2, 3 resimden 3.
    • Pinch the sides of the back panel to remove it and set it aside.
    FixBot'a Sor
    Yorum Ekle
  3. PlayStation Move USB Port Replacement: adım 3, 2 resimden 1. PlayStation Move USB Port Replacement: adım 3, 2 resimden 2.
    • Hold the base of the controller with one hand and with the other carefully pull up on the white spherical piece to remove it.
    FixBot'a Sor
    Yorum Ekle
  4. PlayStation Move USB Port Replacement: adım 4, 2 resimden 1. PlayStation Move USB Port Replacement: adım 4, 2 resimden 2.
    • Push the Lithium Ion battery from its slot to remove it.
    • Be mindful not to damage the wires or wired components, as the battery will still be attached via its connector.
    FixBot'a Sor
    Yorum Ekle
  5. PlayStation Move USB Port Replacement: adım 5, 1 resimden 1.
    • Unscrew the 9mm screw in the battery slot with a PH #00 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  6. PlayStation Move USB Port Replacement: adım 6, 2 resimden 1. PlayStation Move USB Port Replacement: adım 6, 2 resimden 2.
    • Using a plastic opening tool, carefully pry the rumble motor free.
    FixBot'a Sor
    Yorum Ekle
  7. PlayStation Move USB Port Replacement: adım 7, 1 resimden 1.
    • Unscrew the 9mm screw behind the rumble motor slot with a PH #00 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  8. PlayStation Move USB Port Replacement: adım 8, 3 resimden 1. PlayStation Move USB Port Replacement: adım 8, 3 resimden 2. PlayStation Move USB Port Replacement: adım 8, 3 resimden 3.
    • Carefully pinch the plastic sides of the battery slot and lift it (along with the circuit board) from the plastic shell of the move controller.
    FixBot'a Sor
    Yorum Ekle
  9. PlayStation Move USB Port Replacement: adım 9, 2 resimden 1. PlayStation Move USB Port Replacement: adım 9, 2 resimden 2.
    • Using your fingers, carefully pry the square green piece beneath the battery slot free.
    • It is attached via white ribbons which need to be kept intact.
    FixBot'a Sor
    Yorum Ekle
  10. PlayStation Move USB Port Replacement: adım 10, 3 resimden 1. PlayStation Move USB Port Replacement: adım 10, 3 resimden 2. PlayStation Move USB Port Replacement: adım 10, 3 resimden 3.
    • Follow the white ribbon attached to the part you just removed to a smaller, more rectangular piece.
    • Lift the rectangular piece from its slot to free it.
    FixBot'a Sor
    Yorum Ekle
  11. PlayStation Move USB Port Replacement: adım 11, 3 resimden 1. PlayStation Move USB Port Replacement: adım 11, 3 resimden 2. PlayStation Move USB Port Replacement: adım 11, 3 resimden 3.
    • Carefully lift the entire circuit board from the black plastic encasing it.
    • Take extra care not to damage any of the wired components.
    FixBot'a Sor
    Yorum Ekle
  12. PlayStation Move USB Port Replacement, USB Port: adım 12, 1 resimden 1.
    • At the end of the circuit board, you should see a small silver connector port (this is the USB).
    • Using a soldering iron, carefully desolder the port from the board. For help with desoldering, please reference this guide: How To Solder and Desolder Connections
    • In order to reinstall the new USB port, you must solder the new one to the board.
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Sarah Shand
1.996 İtibar
7 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S3-G1, Sullivan Spring 2017 USF Tampa, Team S3-G1, Sullivan Spring 2017 üyesi
USFT-SULLIVAN-S17S3G1
3 Üyeler
15 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 12
Son 30 gün: 49
Her zaman: 3,439
