Ana içeriğe geç
PlayStation Optical Drive Replacement
Neye ihtiyacın var
  1. PlayStation Optical Drive Replacement, Open the Console: adım 1, 1 resimden 1.
    • Before you begin, make sure the console is turned off and unplugged.
    • Turn the console upside down and remove the five 15.8 mm-long Phillips #1 screws.
    FixBot'a Sor
    Yorum Ekle
  2. PlayStation Optical Drive Replacement: adım 2, 2 resimden 1. PlayStation Optical Drive Replacement: adım 2, 2 resimden 2.
    • While holding the top and bottom halves of the console together, flip the console back over. Lift the top cover straight up to remove it.
    FixBot'a Sor
    Yorum Ekle
  3. PlayStation Optical Drive Replacement, Remove the Optical Drive: adım 3, 2 resimden 1. PlayStation Optical Drive Replacement, Remove the Optical Drive: adım 3, 2 resimden 2.
    • Pull the optical drive power cable straight up and out of its socket on the motherboard to disconnect it.
    FixBot'a Sor
    Yorum Ekle
  4. PlayStation Optical Drive Replacement: adım 4, 3 resimden 1. PlayStation Optical Drive Replacement: adım 4, 3 resimden 2. PlayStation Optical Drive Replacement: adım 4, 3 resimden 3.
    • Use the flat end of a spudger to lift up and unlock one side of the data cable's connector on the motherboard. Repeat this step on the other side of the connector.
    • You'll hear a faint click noise when unlocking the connector. Make sure not to apply too much pressure when lifting up on the connector with the spudger, or else damage may result.
    • Gently pull the optical drive data cable straight up and out of its socket on the motherboard to disconnect it.
    FixBot'a Sor
    Yorum Ekle
  5. PlayStation Optical Drive Replacement: adım 5, 2 resimden 1. PlayStation Optical Drive Replacement: adım 5, 2 resimden 2.
    • Lift the optical drive straight up to remove it.
    FixBot'a Sor
    Yorum Ekle
Sonuç
56 farklı kişi bu kılavuzu tamamladı.
Craig Lloyd
42.969 İtibar
82 adet Kılavuz yazıldı
5Kılavuz Yorumları
Laser Drive Models
SCPH-100x : KSM-440AAM and KSM-440ACM
SCPH-550x-700x : KSM-440ADM
SCPH-750x-900x : KSM-440AEM
SCPH-10x : KSM-440BAM
Chances are most, if not all of the original AAM and ACM lasers are worn out.
Some vendors still carry an supposed original KSM-440BAM laser unit only.
I could not make this laser work in a SCPH-1001 unit, even after the transfer of parts.
I heard a rumor of spacers and motherboard adjustment.
This: https://web.archive.org/web/201010090109...
PU-8 test point: CL708, voltage reading to ground without disk - 1.7 volts DC, voltage reading with disk 1.85 volts DC.
Very fine adjustment… I have yet to try this step. Has anyone?
What about spacers? Do I need these?
You must transfer the rubber grommets and the plastic laser cover from the old laser to the new.
If you don’t, the new laser will be too large for the SCPH-1001 chassis.
leafybye - Yanıt Paylaş
What about model SCPH-5501?
janis Nasuta - Yanıt Paylaş
Will a KSM-440BAM optical drive from a scph-1001 ps1 work with a scph-1001 ps1 that had a KSM-440ACM optical drive?
The invader 2 - Yanıt Paylaş
Hello! Has anyone had success with replacing the optical drive on a 1001?
If so, which model of drive was used?
John Reeves - Yanıt Paylaş
which optical drive do you recommend on SCPH-1002?
Juan YT - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 22
Son 7 gün: 122
Son 30 gün: 606
Her zaman: 77,325
