Giriş
If the device loses charge more quickly than expected, or fails to charge, consider using this guide to replace it.
Neye ihtiyacın var
Flip the device so that the screen faces down, with the back facing up.
Unscrew the four screws with a PH000 screwdriver.
Grip the the battery by hand.
Lift the battery, by hand, to remove it from the glue and panel.
Desolder the wires from the motherboard. For detailed information, refer to the Solder and Desolder guide.
Bir başkası bu kılavuzu tamamladı.
