Giriş
The plate which holds the phone as it charges may need to be changed occasionally. This guide will help you remove the plate.
Neye ihtiyacın var
To disconnect the phone cord, squeeze the tab against the connector and pull the cord away from the telephone-line-in-jack.
To disconnect the power cord, grasp the end and pull back and away until it is disconnected.
Once disconnected remove each cord from its track.
Using a Phillips #00 screwdriver, remove the six 7mm screws from the base plate.
With the base turned upside down, grasp the edges of the base plate and gently lift from the rest of the base.
Use a Phillips #00 screwdriver to remove the two 5mm screws from the metal plate.
Use the Philips #00 screwdriver to remove the four 6mm screws from the base cover.
Gently pull the charge plate away from the rest of the base and separate the two pieces of the charge plate.
Bu adımda kullanılan alet:Tweezers$4.99
Use the spudger to gently scrape the glue away from the wire connections.
Use the soldering station to desolder the wire connections.
2 farklı kişi bu kılavuzu tamamladı.
