Ana içeriğe geç
Polyconcept 900-MHz Retro Cordless Telephone Device Motherboard Replacement
Neye ihtiyacın var
  1. Polyconcept 900-MHz Retro Cordless Telephone Device Motherboard Replacement, Removing Power and Telephone Cords: adım 1, 3 resimden 1. Polyconcept 900-MHz Retro Cordless Telephone Device Motherboard Replacement, Removing Power and Telephone Cords: adım 1, 3 resimden 2. Polyconcept 900-MHz Retro Cordless Telephone Device Motherboard Replacement, Removing Power and Telephone Cords: adım 1, 3 resimden 3.
    • To disconnect the phone cord, squeeze the tab against the connector and pull the cord away from the telephone-line-in-jack.
    • To disconnect the power cord, grasp the end and pull back and away until it is disconnected.
    • Once disconnected remove each cord from its track.
  2. Polyconcept 900-MHz Retro Cordless Telephone Device Motherboard Replacement, Removing Screws to Base Plate: adım 2, 1 resimden 1.
    • Using a Phillips #00 screwdriver, remove the six 7mm screws from the base plate.
  3. Polyconcept 900-MHz Retro Cordless Telephone Device Motherboard Replacement, Remove Bottom Plate from Base: adım 3, 3 resimden 1. Polyconcept 900-MHz Retro Cordless Telephone Device Motherboard Replacement, Remove Bottom Plate from Base: adım 3, 3 resimden 2. Polyconcept 900-MHz Retro Cordless Telephone Device Motherboard Replacement, Remove Bottom Plate from Base: adım 3, 3 resimden 3.
    • With the base turned upside down, grasp the edges of the base plate and gently lift from the rest of the base.
    • Two wires lead from the motherboard to the charger plate, so the two parts cannot be completely separated without further steps.
  4. Polyconcept 900-MHz Retro Cordless Telephone Device Motherboard Replacement, Removing Screws: adım 4, 1 resimden 1.
    • Use a Phillips #00 screwdriver to remove the three 6mm screws from the phone and power jack cover plate.
    • Lift the phone and power jack cover plate away from the motherboard.
  5. Polyconcept 900-MHz Retro Cordless Telephone Device Motherboard Replacement, Removing the Motherboard Screw: adım 5, 1 resimden 1.
    • Use a Philips #00 screwdriver to remove the single 6mm screw from the motherboard.
  6. Polyconcept 900-MHz Retro Cordless Telephone Device Motherboard Replacement, Removing Glue Covering for Wire Connections: adım 6, 2 resimden 1. Polyconcept 900-MHz Retro Cordless Telephone Device Motherboard Replacement, Removing Glue Covering for Wire Connections: adım 6, 2 resimden 2.
    • Use the spudger tool to carefully scrape the glue off of the connection points of both the black and red wires.
  7. Polyconcept 900-MHz Retro Cordless Telephone Device Motherboard Replacement, Desoldering Wire Connections: adım 7, 1 resimden 1.
    • Gently lift the motherboard away from the base plate and flip over.
    • Use the soldering station to desolder the wire connections.
    • For further instructions on using the soldering station click here.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 8
Her zaman: 368
