Ana içeriğe geç
Porter-Cable PCC710B Lever Assembly Replacement
Neye ihtiyacın var
  1. Porter-Cable PCC710B Lever Assembly Replacement, Lever assembly: adım 1, 1 resimden 1.
    • Place the tool on its side so the orange and white warning label barcodes are facing up.
    • The lever and battery base of the tool should point toward you.
    FixBot'a Sor
    Yorum Ekle
  2. Porter-Cable PCC710B Lever Assembly Replacement: adım 2, 3 resimden 1. Porter-Cable PCC710B Lever Assembly Replacement: adım 2, 3 resimden 2. Porter-Cable PCC710B Lever Assembly Replacement: adım 2, 3 resimden 3.
    • Use a 5.5 mm nut driver to unscrew the Hex nut.
    • If the Hex nut is not unscrewing easily- you can use a 3 mm Hex head screwdriver to hold the other side of the screw still.
    FixBot'a Sor
    Yorum Ekle
  3. Porter-Cable PCC710B Lever Assembly Replacement: adım 3, 1 resimden 1.
    • Flip the tool over and remove the black screw holding the tool together.
    • Get a good grip on the screw by using pliers to pull the screw out of the tool.
    FixBot'a Sor
    Yorum Ekle
  4. Porter-Cable PCC710B Lever Assembly Replacement: adım 4, 3 resimden 1. Porter-Cable PCC710B Lever Assembly Replacement: adım 4, 3 resimden 2. Porter-Cable PCC710B Lever Assembly Replacement: adım 4, 3 resimden 3.
    • Pinch the lever with your fingers and pull it up and away from the tool. The lever pops right off! You can squeeze on the lever, and it will come off just as easily.
    • When replacing your new lever assembly, make sure the black torsion (the black staple-like hinge) is oriented correctly.
    FixBot'a Sor
    Yorum Ekle
Sonuç
To reassemble your device, follow instruction steps 3 to 1 in reverse order.
Alex Zapata
665 İtibar
7 adet Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 21
Her zaman: 464
