Ana içeriğe geç
Porter-Cable PCE211 Fan Replacement
Neye ihtiyacın var
    1. Porter-Cable PCE211 Fan Replacement, Gearcase: adım 1, 2 resimden 1. Porter-Cable PCE211 Fan Replacement, Gearcase: adım 1, 2 resimden 2.
      • Using the Hex Security SAE 7/32", remove the four 10 mm socket screws at the base of the gearcase.
      FixBot'a Sor
      Yorum Ekle
    2. Porter-Cable PCE211 Fan Replacement: adım 2, 3 resimden 1. Porter-Cable PCE211 Fan Replacement: adım 2, 3 resimden 2. Porter-Cable PCE211 Fan Replacement: adım 2, 3 resimden 3.
      • Grip the body of the impact wrench with one hand and the gearcase in the other and firmly pull to remove it.
      • Be careful about any loose parts when removing the head.
      FixBot'a Sor
      Yorum Ekle
    1. Porter-Cable PCE211 Fan Replacement, Anvil: adım 3, 3 resimden 1. Porter-Cable PCE211 Fan Replacement, Anvil: adım 3, 3 resimden 2. Porter-Cable PCE211 Fan Replacement, Anvil: adım 3, 3 resimden 3.
      • Firmly pull the to remove drill bit holder also known as the anvil.
      • Before replacing the anvil, lubricate the base for the best performance.
      FixBot'a Sor
      Yorum Ekle
    1. Porter-Cable PCE211 Fan Replacement, Motor: adım 4, 3 resimden 1. Porter-Cable PCE211 Fan Replacement, Motor: adım 4, 3 resimden 2. Porter-Cable PCE211 Fan Replacement, Motor: adım 4, 3 resimden 3.
      • This section tends to get messy so it would be best to have a paper towel or microfiber towel handy.
      • Pull the motor out with your hands.
      FixBot'a Sor
      Yorum Ekle
    2. Porter-Cable PCE211 Fan Replacement: adım 5, 3 resimden 1. Porter-Cable PCE211 Fan Replacement: adım 5, 3 resimden 2. Porter-Cable PCE211 Fan Replacement: adım 5, 3 resimden 3.
      • Wipe out the old grease with a towel. Use the appropriate motor grease for electric tools to lubricate the top area, base of the motor, and the space the motor sits.
      FixBot'a Sor
      Yorum Ekle
    1. Porter-Cable PCE211 Fan Replacement, Rear Housing: adım 6, 2 resimden 1. Porter-Cable PCE211 Fan Replacement, Rear Housing: adım 6, 2 resimden 2.
      • Remove the four 6 mm screws using a Phillips #2 screwdriver.
      • The screws are tight so you will need to use a bit of arm strength.
      FixBot'a Sor
      Yorum Ekle
    2. Porter-Cable PCE211 Fan Replacement: adım 7, 2 resimden 1. Porter-Cable PCE211 Fan Replacement: adım 7, 2 resimden 2.
      • Pull the rear housing off the back of the impact wrench.
      • Be careful when removing the rear case that loose parts don't get damaged.
      FixBot'a Sor
      Yorum Ekle
    1. Porter-Cable PCE211 Fan Replacement, Grip: adım 8, 2 resimden 1. Porter-Cable PCE211 Fan Replacement, Grip: adım 8, 2 resimden 2.
      • Using the Phillips #2 screwdriver, remove the three 8 mm screws from the grip of the impact wrench.
      FixBot'a Sor
      Yorum Ekle
    2. Porter-Cable PCE211 Fan Replacement: adım 9, 2 resimden 1. Porter-Cable PCE211 Fan Replacement: adım 9, 2 resimden 2.
      • Pull the grip from the body of the impact wrench.
      FixBot'a Sor
      Yorum Ekle
    1. Porter-Cable PCE211 Fan Replacement, Fan: adım 10, 2 resimden 1. Porter-Cable PCE211 Fan Replacement, Fan: adım 10, 2 resimden 2.
      • Lift the hammer block (which is attached to the fan) out of the case.
      • It is a little heavy so be careful when lifting it out.
      FixBot'a Sor
      Yorum Ekle
    2. Porter-Cable PCE211 Fan Replacement: adım 11, 2 resimden 1. Porter-Cable PCE211 Fan Replacement: adım 11, 2 resimden 2.
      • If you're doing maintenance and the fan isn't damage, use a microfiber cloth to clean the fan.
      • Wipe well until there's no residue or oil lubricant.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Layla Berry
678 İtibar
7 adet Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 25
Her zaman: 425
