Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
To Start The Dissasembly, Flip The Cube Upside-Down, and unplug it.
Next, push on the handle, it should pop up.
Now, pull up on the cube by the handle, all of the guts should come out.
As you might notice, the cube's guts only go in one way, the ports facing the back of the enclosure
Removing the Ram
Start by fliping the cube so that the side with the graphics card is facing you, you may want to push the handle back in.
There are 3 RAM Slots, they are Standard PC100 Ram. The cube can support up to 1.5GB of ram, that's a 512MB Stick In All 3 Slots.
Remove the ram, just like any other kind of ram.
Airport Card
The Cube Uses the standard PCMCIA 802.11b Airport card commonly found in macs from 1999-2004
Flip the cube to the side with the airport card attatched. Remove the antenna cable, then grasp the card by the plastic tab, and pull it out of it's socket.
The Graphics Card
The Cube came standard with a Mac ATI Rage 128 Pro 16MB AGP Card. ATI Radeon (32MB) and nVidia GeForce 2MX (32MB) cards were BTO options.
Remove these T10 screws:
Then, pull the top piece of metal off of the computer,
Now to free the card, pull this tab towards you and with some persuasion, the card should come free.
Oops! Oh well, even without the brittle plastic tab, the card isn't going anywhere.
Then, remove the card and set it aside.
Removing the AGP Riser card
Pull the card out of the PCI Socket, and no, unfortunately, you can't use this to put an AGP card in a PCI slot in a PC.
Once the card is free, mind the 3 cables attached to it, remove these 2 cables first.
The third cable is glued to the AGP board, unplug it from the logic board instead.
Removing the 56K Modem
Remove the 2 T10 Torx Screws
Then, pull the 56k modem out, there is a socket on the back of it, so be careful!
Removing the Voltage Regulator Module.
This board is called the DC/DC board, or the Voltage Regulator Module. It takes the power from the power brick and regulates the power to different components of the Cube.
First, disconnect the power connector.
Then release the white clip on the connector socket, which is accessed from the side of the core.
With a little persuasion, the board comes out of it's socket(it's hard to show how the board comes out, but in person, it's pretty self explanatory)
The Logic Board
Unfortunately, this as far as I am going to dissect my cube, partially because I still use it frequently, but here is an overview of the cube.
450Mhz or 500Mhz PowerPC G4 Processor
Shipped with 64MB ram, supports up to 1.5GB of PC100 or PC133
One PCI Slot(Converted to AGP via adaptor)
No Onboard Audio.(Unfortunately)
8 Yorum
This is great! What a beautiful machine that was.
Awesome teardown, Chris! Thanks for posting it.
