Ana içeriğe geç
PowerBook G3 Pismo Inverter Replacement
Neye ihtiyacın var
  1. PowerBook G3 Pismo Inverter Replacement, Keyboard: adım 1, 1 resimden 1.
    • Turn the keyboard locking screw so that it is parallel to the space bar.
    • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
    • Lift the keyboard out by pulling it up and away from you. Rest the keyboard, face down, on top of the track pad.
    FixBot'a Sor
    Yorum Ekle
  2. PowerBook G3 Pismo Inverter Replacement: adım 2, 1 resimden 1.
    • Pull the keyboard ribbon straight up from the logic board. Place the keyboard aside.
    • The connector may be tight. Gently rock the connector from side to side while pulling directly upward to free it. You can use this technique on many of the cards and cables you'll be disconnecting.
    • Make sure you have removed the laptop battery and CD/DVD modules from the expansion bays before proceeding.
    FixBot'a Sor
    Yorum Ekle
  3. PowerBook G3 Pismo Inverter Replacement: adım 3, 1 resimden 1.
    • Your laptop should look approximately like this.
    FixBot'a Sor
    Yorum Ekle
  4. PowerBook G3 Pismo Inverter Replacement, Heat Shield: adım 4, 1 resimden 1.
    • Remove the two silver Phillips #1 screws that attach the heat shield to the internal metal framework.
    • Lift the heat shield up and pull it toward you.
    FixBot'a Sor
    Yorum Ekle
  5. PowerBook G3 Pismo Inverter Replacement: adım 5, 1 resimden 1.
    FixBot'a Sor
    Yorum Ekle
  6. PowerBook G3 Pismo Inverter Replacement, Airport Card: adım 6, 1 resimden 1.
    • Skip this step if your computer does not have an Airport card installed.
    • Firmly grasp the plastic tab attached to the Airport card and pull up and then to the right.
    • The Airport card is still attached to the antenna cable, so don't just yank it out of the slot.
    FixBot'a Sor
    Yorum Ekle
  7. PowerBook G3 Pismo Inverter Replacement: adım 7, 1 resimden 1.
    • Disconnect the antenna cable from the Airport card.
    FixBot'a Sor
    Yorum Ekle
  8. PowerBook G3 Pismo Inverter Replacement, PRAM Battery: adım 8, 1 resimden 1.
    • Pull the battery cable directly up from the logic board.
    • Remove the battery from its holder by pulling up and to the left.
    FixBot'a Sor
    Yorum Ekle
  9. PowerBook G3 Pismo Inverter Replacement: adım 9, 1 resimden 1.
    FixBot'a Sor
    Yorum Ekle
  10. PowerBook G3 Pismo Inverter Replacement, Heat Sink: adım 10, 1 resimden 1.
    • Remove the long silver Phillips #1 screw from the heat sink.
    • Remove the two T8 Torx screws that attach the heat sink to the processor.
    FixBot'a Sor
    Yorum Ekle
  11. PowerBook G3 Pismo Inverter Replacement: adım 11, 1 resimden 1.
    • Lift the heat sink up from the left side and pull it out.
    • If you need to mount the heat sink back into the laptop, we have a thermal paste guide that makes replacing the thermal compound easy.
    FixBot'a Sor
    Yorum Ekle
  12. PowerBook G3 Pismo Inverter Replacement, Processor: adım 12, 1 resimden 1.
    • Grasp the plastic tab on the processor's right side and pull it directly up.
    • Some processors may be missing the plastic pull tab. In this case, we suggest using a non-metal tool to gently pry up the processor. Slip the tool's thin edge under the front right corner of the processor and carefully pry it up.
    FixBot'a Sor
    Yorum Ekle
  13. PowerBook G3 Pismo Inverter Replacement: adım 13, 1 resimden 1.
    FixBot'a Sor
    Yorum Ekle
  14. PowerBook G3 Pismo Inverter Replacement, Modem: adım 14, 1 resimden 1.
    • Remove the black Torx screw from the right side of the modem.
    • Remove the small black plastic rectangle with four holes.
    FixBot'a Sor
    Yorum Ekle
  15. PowerBook G3 Pismo Inverter Replacement: adım 15, 1 resimden 1.
    • Use the tips of your fingers, a spudger, or a flat non-metal tool to get under the modem's edge and pry it up from its socket.
    FixBot'a Sor
    Yorum Ekle
  16. PowerBook G3 Pismo Inverter Replacement: adım 16, 1 resimden 1.
    • Disconnect the cable from the right side of the modem.
    FixBot'a Sor
    Yorum Ekle
  17. PowerBook G3 Pismo Inverter Replacement, Hard Drive: adım 17, 1 resimden 1.
    • Grasp the orange cable at the left end of the hard drive and disconnect it from the logic board.
    • Try to grasp the cable on the plastic connector rather than on the flexible cable section.
    FixBot'a Sor
    Yorum Ekle
  18. PowerBook G3 Pismo Inverter Replacement: adım 18, 1 resimden 1.
    • Grasp the plastic tab and pull the hard drive up and to the left, making sure that the metal bracket doesn't catch on the black plastic casing.
    FixBot'a Sor
    Yorum Ekle
  19. PowerBook G3 Pismo Inverter Replacement: adım 19, 1 resimden 1.
    FixBot'a Sor
    Yorum Ekle
  20. PowerBook G3 Pismo Inverter Replacement, Clutch Cover: adım 20, 1 resimden 1.
    • Push the display back so that it lies flat.
    • Slip your index finger or a nylon tool under the clutch cover near the power button and pull gently upward until you feel it come free.
    • Repeat the previous step on the left side.
    FixBot'a Sor
    Yorum Ekle
  21. PowerBook G3 Pismo Inverter Replacement: adım 21, 1 resimden 1.
    • Lift the clutch cover up and off, rotating it toward yourself.
    FixBot'a Sor
    Yorum Ekle
  22. PowerBook G3 Pismo Inverter Replacement, Inverter: adım 22, 1 resimden 1.
    • Grasp the orange display data cable and disconnect it from the logic board.
    FixBot'a Sor
    Yorum Ekle
  23. PowerBook G3 Pismo Inverter Replacement: adım 23, 1 resimden 1.
    • Remove the single black Torx screw that fastens the display cable to the plastic casing.
    • Grasp the thin display inverter board at its left end; lift up and rotate toward yourself.
    • There are two tabs that hold the display inverter in place; these are what you need to get past in order to pull the board free.
    FixBot'a Sor
    Yorum Ekle
  24. PowerBook G3 Pismo Inverter Replacement: adım 24, 1 resimden 1.
    • Disconnect the white inverter cable from the right end of the board
    FixBot'a Sor
    Yorum Ekle
  25. PowerBook G3 Pismo Inverter Replacement: adım 25, 1 resimden 1.
    • Disconnect the inverter plug, pulling directly up from the logic board.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Ekli Belgeler
iRobot
1 İtibar
636 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 11
Son 30 gün: 49
Her zaman: 8,315
