PowerBook G4 Aluminum 12" 1-1.5 GHz Keyboard Replacement
Giriş
1. adıma gitThis guide shows the hidden screws you must remove when replacing the keyboard.
Neye ihtiyacın var
Parçalar
Aletler
Daha fazlasını göster…
Use a coin to turn the battery locking screw 90 degrees to the right.
Lift the battery out of the computer.
Remove the four Phillips screws from the memory door.
Slide the memory door away from the memory compartment.
On the keyboard, remove the F1, F2, F11, and F12 keys.
This is scary - take a deep breath before continuing. Place your index finger under the upper left corner of the key and lift up until you hear a click. Then, transfer your finger to the left edge of the key and lift up to pull the key off.
You're freeing the two tabs on the left of the key from the two small holes in the plastic scissors mechanism.
16 farklı kişi bu kılavuzu tamamladı.
