Ana içeriğe geç
PowerShot G7 X Mark II LCD Screen Replacement
Brandon
Brandon ve 4 diğer katkıda bulunanlar
En son June 10, 2024 tarihinde güncellendi
10 - 15 dakika
Kolay
İşlem Görüntüleri
Daha Fazla Görsel Gerekli
This guide will show how to replace the LCD screen on the camera. This replacement is useful if the LCD screen has been cracked or has stopped working.
Neye ihtiyacın var
Aletler
Daha fazlasını göster…
  1. PowerShot G7 X Mark II LCD Screen Replacement, LCD Screen: adım 1, 1 resimden 1.
    • Use a Philips #000 screwdriver to remove the three 2mm screws on the bottom of the LCD screen.
  2. PowerShot G7 X Mark II LCD Screen Replacement: adım 2, 1 resimden 1.
    • Tilt the LCD screen all the way up and use a Phillips #000 screwdriver to remove the three 4mm screws from the back of the LCD screen.
  3. PowerShot G7 X Mark II LCD Screen Replacement, Remove back panel from LCD screen: adım 3, 1 resimden 1.
    • Use a spudger tool to release the ribbon cable from the ZIF connector.
    • The cable is thin and delicate. Detach with care.
    • Gently pry off the screen until the double-sided tape behind the back panel gives in.
  4. PowerShot G7 X Mark II LCD Screen Replacement: adım 4, 1 resimden 1.
    • The screen is detached and can now be replaced.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Brandon
626 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 12-3, Eyestone Spring 2017 USF Tampa, Team 12-3, Eyestone Spring 2017 üyesi
USFT-EYESTONE-S17S12G3
3 Üyeler
5Kılavuz Yorumları
Are there any problems with the replacement screen? It’s a touch screen, just making sure the functionality of the screen is still intact.
Andrew Baez - Yanıt
These directions do not give enough information. The screed is glued into the frame. The replacement parts do not come with the circuit board.
alan saltus - Yanıt
Did you successfully replace the screen? I took off the screws, and got to the detaching the wire stage but then discovered as you said “the glue”. Any further insight would be appreciated!
rachelkernali -
My G7X lost one of the 2 screws holding the screen: do you know where I can find them?
paolofarinella - Yanıt
on ebay or amazon. you can order it
nicole -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 24
Son 30 gün: 121
Her zaman: 9,395
