Ana içeriğe geç
ProntoTec Axius Motherboard Replacement
Neye ihtiyacın var
    1. ProntoTec Axius Motherboard Replacement, Motherboard: adım 1, 1 resimden 1.
      • Make sure the device is completely turned off before you begging taking it apart to avoid electrocution risks.
      • Place the tablet face-up on a flat table.
      FixBot'a Sor
      Yorum Ekle
    2. ProntoTec Axius Motherboard Replacement: adım 2, 1 resimden 1.
      • Starting near the headphone port, fit the flat end of the spudger in between the screen and back case.
      • Pry the back case from the screen around each point on the device to release the clips securing the case halves to each other.
      FixBot'a Sor
      Yorum Ekle
    3. ProntoTec Axius Motherboard Replacement: adım 3, 1 resimden 1.
      • Gently remove the back case of the device and lay it in a flat surface as shown in the photo.
      • Make sure not to sever the wires (red and black) connected to the speaker that is located in the back case.
      FixBot'a Sor
      Yorum Ekle
    4. ProntoTec Axius Motherboard Replacement: adım 4, 2 resimden 1. ProntoTec Axius Motherboard Replacement: adım 4, 2 resimden 2.
      • Remove only the yellow tape that touches the motherboard
      • Be careful not to cut or damage the wires (red and black) that connect the battery to the motherboard.
      FixBot'a Sor
      Yorum Ekle
    5. ProntoTec Axius Motherboard Replacement: adım 5, 3 resimden 1. ProntoTec Axius Motherboard Replacement: adım 5, 3 resimden 2. ProntoTec Axius Motherboard Replacement: adım 5, 3 resimden 3.
      • Use a Phillips screwdriver (PH00) to unscrew the two screws that connects the motherboard to the device
      • Be careful not to cut or damage the wires (red and black) that connect the motherboard to the battery.
      FixBot'a Sor
      Yorum Ekle
    6. ProntoTec Axius Motherboard Replacement: adım 6, 2 resimden 1. ProntoTec Axius Motherboard Replacement: adım 6, 2 resimden 2.
      • Using a soldering iron, desolder the contact points of the speaker, battery and screen on the motherboard
      • If soldering is new to you, check out this helpful guide on soldering and desoldering connections.
      • Use pliers to pull the wire from the board
      FixBot'a Sor
      Yorum Ekle
    7. ProntoTec Axius Motherboard Replacement: adım 7, 2 resimden 1. ProntoTec Axius Motherboard Replacement: adım 7, 2 resimden 2.
      • Using the spudger, disconnect the ribbon cable connecting the camera to the motherboard
      FixBot'a Sor
      Yorum Ekle
    8. ProntoTec Axius Motherboard Replacement: adım 8, 3 resimden 1. ProntoTec Axius Motherboard Replacement: adım 8, 3 resimden 2. ProntoTec Axius Motherboard Replacement: adım 8, 3 resimden 3.
      • Using the spudger, push the black tabs towards the ribbon cable to unlock the ribbon cables that connect the screen to the motherboard.
      • Gently pull and remove the ribbon cables from the motherboard
      FixBot'a Sor
      Yorum Ekle
    9. ProntoTec Axius Motherboard Replacement: adım 9, 2 resimden 1. ProntoTec Axius Motherboard Replacement: adım 9, 2 resimden 2.
      • Using the flat side of the spudger, lift up the mother board to disconnect from the screen.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Estelle Hatem
156 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 5-3, Martin Fall 2016 UMass Dartmouth, Team 5-3, Martin Fall 2016 üyesi
UMASSD-MARTIN-F16S5G3
3 Üyeler
15 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 30
Her zaman: 647
