Ana içeriğe geç
Protocol Dronium III AP Light Bulb Replacement
Neye ihtiyacın var
  1. Protocol Dronium III AP Light Bulb Replacement, Drone Battery Pack: adım 1, 2 resimden 1. Protocol Dronium III AP Light Bulb Replacement, Drone Battery Pack: adım 1, 2 resimden 2.
    • Ensure the drone is powered off.
    • Press in and lift battery compartment cover.
    • A soft pry tool may be used for easier access.
  2. Protocol Dronium III AP Light Bulb Replacement: adım 2, 1 resimden 1.
    • Remove battery pack from body of drone.
  3. Protocol Dronium III AP Light Bulb Replacement: adım 3, 2 resimden 1. Protocol Dronium III AP Light Bulb Replacement: adım 3, 2 resimden 2.
    • Disconnect white connectors between the battery pack and drone.
  4. Protocol Dronium III AP Light Bulb Replacement, L.E.D. Bulb(s): adım 4, 1 resimden 1.
    • Remove the eight (8) 5mm Philips screws attaching the motor arms to the body using a Philips J00 screwdriver.
  5. Protocol Dronium III AP Light Bulb Replacement: adım 5, 2 resimden 1. Protocol Dronium III AP Light Bulb Replacement: adım 5, 2 resimden 2.
    • Remove the six (6) 5mm Philips screws attaching the Body Cover to the Body of the drone using a Philips J00 screwdriver.
    • Remove the Body Cover.
  6. Protocol Dronium III AP Light Bulb Replacement: adım 6, 2 resimden 1. Protocol Dronium III AP Light Bulb Replacement: adım 6, 2 resimden 2.
    • Remove the two (2) 5mm Philips screws attaching the Motherboard to the body of the drone using a Philips J00 screwdriver.
    • Lift the Motherboard off the mounting position.
    • Do not pull hard on the Motherboard as solder connections are fragile.
  7. Protocol Dronium III AP Light Bulb Replacement: adım 7, 2 resimden 1. Protocol Dronium III AP Light Bulb Replacement: adım 7, 2 resimden 2.
    • This step contains a tool that can present a potential burn hazard.
    • Prepare and warm up a soldering iron.
    • Position Motherboard so that the L.E.D. bulb solder joints are accessible.
    • Use the soldering iron to melt the solder joints.
    • For more detailed instructions on how to solder, visit out How to Solder and Desolder Connections guide.
    • Remove the L.E.D. bulb from the Motherboard
Sonuç
Steven Mooers
401 İtibar
4 adet Kılavuz yazıldı
Ekip
UW Tacoma, Team S1-G1, Rose Fall 2017 UW Tacoma, Team S1-G1, Rose Fall 2017 üyesi
UWT-ROSE-F17S1G1
4 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 7
Her zaman: 313
