Ana içeriğe geç
Protocol Galileo Stealth Battery Replacement
stephen R masalewicz
stephen R masalewicz ve 3 diğer katkıda bulunanlar
En son June 19, 2018 tarihinde güncellendi
2 dakika
Kolay
This guide will walk you through how to safely and effectively remove the battery from your drone. This is a relatively simple process that does not require any tools or prerequisite steps. This guide is not required to charge your drone battery, but may be useful if the battery becomes defective.
  1. Protocol Galileo Stealth Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Locate the door to the battery compartment on the underside of the drone.
  2. Protocol Galileo Stealth Battery Replacement: adım 2, 1 resimden 1.
    • Open the door to the battery compartment by pressing in the clip on the door and carefully lifting until the door is fully open.
  3. Protocol Galileo Stealth Battery Replacement: adım 3, 1 resimden 1.
    • First pull out the wires located to the side of the battery.
    • Carefully remove the battery from the battery compartment
    • The battery can be a bit difficult to remove, but if the wires are held firmly to the battery, the battery will eventually come out by lightly pulling on the battery and wires simultaneously.
    • The small black and white wire with the white plug will not be connected to the drone, just be sure the plug does not get stuck in the battery compartment and damaged while removing the battery. This is rarely an issue.
  4. Protocol Galileo Stealth Battery Replacement: adım 4, 1 resimden 1.
    • Disconnect the two ends of the wires by lightly pulling them apart.
Sonuç
273 İtibar
2 adet Kılavuz yazıldı
Ekip
UW Stout, Team S8-G4, Ogden Spring 2018 UW Stout, Team S8-G4, Ogden Spring 2018 üyesi
UWSTOUT-OGDEN-S18S8G4
4 Üyeler
6 adet Kılavuz yazıldı
Bir Yorum
Please were can buy the battery
odoffin Kehinde - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 659
