Ana içeriğe geç
Protocol Neo-Drone AP Controller Switch Replacement
Neye ihtiyacın var
  1. Protocol Neo-Drone AP Controller Switch Replacement, Controller Switch: adım 1, 2 resimden 1. Protocol Neo-Drone AP Controller Switch Replacement, Controller Switch: adım 1, 2 resimden 2.
    • Remove the single 6.5mm Phillips #1 screw from the battery cover.
    • Remove the three AAA batteries.
  2. Protocol Neo-Drone AP Controller Switch Replacement: adım 2, 2 resimden 1. Protocol Neo-Drone AP Controller Switch Replacement: adım 2, 2 resimden 2.
    • Remove seven 6.5mm Phillips #1 screws from the back panel.
    • Pull the back panel up to separate it from the front panel.
  3. Protocol Neo-Drone AP Controller Switch Replacement: adım 3, 2 resimden 1. Protocol Neo-Drone AP Controller Switch Replacement: adım 3, 2 resimden 2.
    • Remove three 4.5mm Phillips #1 screws from the motherboard.
    • Pull the motherboard out of the case.
  4. Protocol Neo-Drone AP Controller Switch Replacement: adım 4, 2 resimden 1. Protocol Neo-Drone AP Controller Switch Replacement: adım 4, 2 resimden 2.
    • Here is a link to the iFixit Soldering Guide
    • Use a soldering iron to remove the solder form the motherboard.
Sonuç
Andrew
291 İtibar
2 adet Kılavuz yazıldı
Ekip
IUPUI, Team S2-G3, Harley Summer 2018 IUPUI, Team S2-G3, Harley Summer 2018 üyesi
IUPUI-HARLEY-SU18S2G3
4 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 6
Her zaman: 300
