Ana içeriğe geç
Protocol Videodrone AP Camera Replacement
Neye ihtiyacın var
    1. Protocol Videodrone AP Camera Replacement, Camera: adım 1, 1 resimden 1.
      • Power off the drone before proceeding with this repair.
      FixBot'a Sor
      Yorum Ekle
    2. Protocol Videodrone AP Camera Replacement: adım 2, 1 resimden 1.
      • Remove the propeller screws (1 per propeller).
      • You can use the Phillips #0 screwdriver if you don't own the one included with drone.
      FixBot'a Sor
      Yorum Ekle
    3. Protocol Videodrone AP Camera Replacement: adım 3, 2 resimden 1. Protocol Videodrone AP Camera Replacement: adım 3, 2 resimden 2.
      • Remove the screws holding on the propeller guards using the Phillips #0 screwdriver (2 per propeller guard).
      FixBot'a Sor
      Yorum Ekle
    4. Protocol Videodrone AP Camera Replacement: adım 4, 2 resimden 1. Protocol Videodrone AP Camera Replacement: adım 4, 2 resimden 2.
      • Using the Phillips #0 screwdriver to remove the eight screws securing the body of the drone.
      FixBot'a Sor
      Yorum Ekle
    5. Protocol Videodrone AP Camera Replacement: adım 5, 1 resimden 1.
      • Remove the case.
      FixBot'a Sor
      Yorum Ekle
    6. Protocol Videodrone AP Camera Replacement: adım 6, 1 resimden 1.
      • Remove the propeller motor screws (3 per motor).
      • The plastic screw housing is attached to the motor.
      FixBot'a Sor
      Yorum Ekle
    7. Protocol Videodrone AP Camera Replacement: adım 7, 3 resimden 1. Protocol Videodrone AP Camera Replacement: adım 7, 3 resimden 2. Protocol Videodrone AP Camera Replacement: adım 7, 3 resimden 3.
      • Depress the tab to open the battery housing.
      • Disconnect the battery connectors
      • Remove the battery.
      FixBot'a Sor
      Yorum Ekle
    8. Protocol Videodrone AP Camera Replacement: adım 8, 1 resimden 1.
      • Using the Phillips #0 screwdriver, remove the four circuit board screws.
      • Remove circuit board.
      FixBot'a Sor
      Yorum Ekle
    9. Protocol Videodrone AP Camera Replacement: adım 9, 2 resimden 1. Protocol Videodrone AP Camera Replacement: adım 9, 2 resimden 2.
      • Remove the four battery housing screws with the Phillips #0 screwdriver.
      • Remove the battery housing to reveal the camera circuit board underneath.
      FixBot'a Sor
      Yorum Ekle
    10. Protocol Videodrone AP Camera Replacement: adım 10, 1 resimden 1.
      • Pull upwards on the strip to remove the camera out of its slot.
      FixBot'a Sor
      Yorum Ekle
    11. Protocol Videodrone AP Camera Replacement: adım 11, 1 resimden 1.
      • Remove camera circuit board from housing.
      • On the main circuit board, desolder the the connection points connecting to camera circuit board.
      • Four wires need to be desoldered. Colours include: Red, white, black and blue.
      • For more information on soldering connections, please visit the How to Solder and Desolder Connections guide.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Karan Paranganat
352 İtibar
2 adet Kılavuz yazıldı
Ekip
IUPUI, Team S2-G2, Harley Fall 2019 IUPUI, Team S2-G2, Harley Fall 2019 üyesi
IUPUI-HARLEY-F19S2G2
3 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 14
Her zaman: 530
