Ana içeriğe geç
Punkt MP02 Keyboard Membrane Replacement
Neye ihtiyacın var
  1. Punkt MP02 Keyboard Membrane Replacement, Battery: adım 1, 2 resimden 1. Punkt MP02 Keyboard Membrane Replacement, Battery: adım 1, 2 resimden 2.
    • Use a SIM card eject tool to to eject and remove the SIM card tray on the side of the phone.
    FixBot'a Sor
    Yorum Ekle
  2. Punkt MP02 Keyboard Membrane Replacement: adım 2, 2 resimden 1. Punkt MP02 Keyboard Membrane Replacement: adım 2, 2 resimden 2.
    • The back panel is held on by glue and multiple tabs.
    • Slide a Jimmy into the seam between the back panel and the chassis.
    • Slide the Jimmy around the perimeter to release the back panel, with care not to damage the retaining clips.
    • Clean any old adhesive with a spudger and isopropyl alcohol, then apply new adhesive to the back panel before reinstalling it.
    FixBot'a Sor
    Yorum Ekle
  3. Punkt MP02 Keyboard Membrane Replacement: adım 3, 3 resimden 1. Punkt MP02 Keyboard Membrane Replacement: adım 3, 3 resimden 2. Punkt MP02 Keyboard Membrane Replacement: adım 3, 3 resimden 3.
    • Use a Phillips screwdriver to remove the two adjacent 3 mm Phillips screws.
    FixBot'a Sor
    Yorum Ekle
  4. Punkt MP02 Keyboard Membrane Replacement: adım 4, 3 resimden 1. Punkt MP02 Keyboard Membrane Replacement: adım 4, 3 resimden 2. Punkt MP02 Keyboard Membrane Replacement: adım 4, 3 resimden 3.
    • Insert a Jimmy into the seam between the front and back case.
    • Slide the Jimmy around the perimeter while prying to separate the front and back case.
    FixBot'a Sor
    Yorum Ekle
  5. Punkt MP02 Keyboard Membrane Replacement: adım 5, 2 resimden 1. Punkt MP02 Keyboard Membrane Replacement: adım 5, 2 resimden 2.
    • Use a spudger to pry up and disconnect the battery press connector.
    • Make sure to pry under the connector itself and not on the board.
    FixBot'a Sor
    Yorum Ekle
  6. Punkt MP02 Keyboard Membrane Replacement: adım 6, 2 resimden 1. Punkt MP02 Keyboard Membrane Replacement: adım 6, 2 resimden 2.
    • Gently pry the battery off with the spudger tool.
    • Take care not to bend, warp, or puncture the battery during removal.
    FixBot'a Sor
    Yorum Ekle
  7. Punkt MP02 Keyboard Membrane Replacement, Screen: adım 7, 3 resimden 1. Punkt MP02 Keyboard Membrane Replacement, Screen: adım 7, 3 resimden 2. Punkt MP02 Keyboard Membrane Replacement, Screen: adım 7, 3 resimden 3.
    • Remove the six 3 mm-long Phillips screws located on the board beneath the battery.
    FixBot'a Sor
    Yorum Ekle
  8. Punkt MP02 Keyboard Membrane Replacement: adım 8, 3 resimden 1. Punkt MP02 Keyboard Membrane Replacement: adım 8, 3 resimden 2. Punkt MP02 Keyboard Membrane Replacement: adım 8, 3 resimden 3.
    • Remove the antenna coaxial connectors on the board with a spudger by gently prying straight up where they are connected on the board.
    FixBot'a Sor
    Yorum Ekle
  9. Punkt MP02 Keyboard Membrane Replacement: adım 9, 3 resimden 1. Punkt MP02 Keyboard Membrane Replacement: adım 9, 3 resimden 2. Punkt MP02 Keyboard Membrane Replacement: adım 9, 3 resimden 3.
    • Flip up the two black locking flaps securing each of the two ribbon cables.
    • Disconnect the two ribbon cables.
    FixBot'a Sor
    Yorum Ekle
  10. Punkt MP02 Keyboard Membrane Replacement: adım 10, 2 resimden 1. Punkt MP02 Keyboard Membrane Replacement: adım 10, 2 resimden 2.
    • Using your thumbs, push the board up so that the clip can slide out of the indent.
    • Use a spudger to gently separate the boards.
    • Ensure that the antennae slide through the holes—do not accidentally pull these off.
    FixBot'a Sor
    Yorum Ekle
  11. Punkt MP02 Keyboard Membrane Replacement: adım 11, 3 resimden 1. Punkt MP02 Keyboard Membrane Replacement: adım 11, 3 resimden 2. Punkt MP02 Keyboard Membrane Replacement: adım 11, 3 resimden 3.
    • Use a spudger to lift and disconnect the screen press connector.
    • Make sure to pry up on the edge of the connector, not the board itself.
    • Remove the screen.
    FixBot'a Sor
    Yorum Ekle
  12. Punkt MP02 Keyboard Membrane Replacement, Keyboard Membrane: adım 12, 3 resimden 1. Punkt MP02 Keyboard Membrane Replacement, Keyboard Membrane: adım 12, 3 resimden 2. Punkt MP02 Keyboard Membrane Replacement, Keyboard Membrane: adım 12, 3 resimden 3.
    • Remove the 3 (3mm) Phillips head screws from the board.
    FixBot'a Sor
    Yorum Ekle
  13. Punkt MP02 Keyboard Membrane Replacement: adım 13, 2 resimden 1. Punkt MP02 Keyboard Membrane Replacement: adım 13, 2 resimden 2.
    • Use a spudger to gently pry the board up and remove it.
    FixBot'a Sor
    Yorum Ekle
  14. Punkt MP02 Keyboard Membrane Replacement: adım 14, 3 resimden 1. Punkt MP02 Keyboard Membrane Replacement: adım 14, 3 resimden 2. Punkt MP02 Keyboard Membrane Replacement: adım 14, 3 resimden 3.
    • Peel the keyboard membrane off the phone casing.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Gloria Enchill
97 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 26
Her zaman: 100
