Ana içeriğe geç
Punkt MP02 Screen Replacement
Neye ihtiyacın var
  1. Punkt MP02 Screen Replacement, Battery: adım 1, 2 resimden 1. Punkt MP02 Screen Replacement, Battery: adım 1, 2 resimden 2.
    • Use a SIM card eject tool to to eject and remove the SIM card tray on the side of the phone.
    FixBot'a Sor
    Yorum Ekle
  2. Punkt MP02 Screen Replacement: adım 2, 2 resimden 1. Punkt MP02 Screen Replacement: adım 2, 2 resimden 2.
    • The back panel is held on by glue and multiple tabs.
    • Slide a Jimmy into the seam between the back panel and the chassis.
    • Slide the Jimmy around the perimeter to release the back panel, with care not to damage the retaining clips.
    • Clean any old adhesive with a spudger and isopropyl alcohol, then apply new adhesive to the back panel before reinstalling it.
    FixBot'a Sor
    Yorum Ekle
  3. Punkt MP02 Screen Replacement: adım 3, 3 resimden 1. Punkt MP02 Screen Replacement: adım 3, 3 resimden 2. Punkt MP02 Screen Replacement: adım 3, 3 resimden 3.
    • Use a Phillips screwdriver to remove the two adjacent 3 mm Phillips screws.
    FixBot'a Sor
    Yorum Ekle
  4. Punkt MP02 Screen Replacement: adım 4, 3 resimden 1. Punkt MP02 Screen Replacement: adım 4, 3 resimden 2. Punkt MP02 Screen Replacement: adım 4, 3 resimden 3.
    • Insert a Jimmy into the seam between the front and back case.
    • Slide the Jimmy around the perimeter while prying to separate the front and back case.
    FixBot'a Sor
    Yorum Ekle
  5. Punkt MP02 Screen Replacement: adım 5, 2 resimden 1. Punkt MP02 Screen Replacement: adım 5, 2 resimden 2.
    • Use a spudger to pry up and disconnect the battery press connector.
    • Make sure to pry under the connector itself and not on the board.
    FixBot'a Sor
    Yorum Ekle
  6. Punkt MP02 Screen Replacement: adım 6, 2 resimden 1. Punkt MP02 Screen Replacement: adım 6, 2 resimden 2.
    • Gently pry the battery off with the spudger tool.
    • Take care not to bend, warp, or puncture the battery during removal.
    FixBot'a Sor
    Yorum Ekle
  7. Punkt MP02 Screen Replacement, Screen: adım 7, 3 resimden 1. Punkt MP02 Screen Replacement, Screen: adım 7, 3 resimden 2. Punkt MP02 Screen Replacement, Screen: adım 7, 3 resimden 3.
    • Remove the six 3 mm-long Phillips screws located on the board beneath the battery.
    FixBot'a Sor
    Yorum Ekle
  8. Punkt MP02 Screen Replacement: adım 8, 3 resimden 1. Punkt MP02 Screen Replacement: adım 8, 3 resimden 2. Punkt MP02 Screen Replacement: adım 8, 3 resimden 3.
    • Remove the antenna coaxial connectors on the board with a spudger by gently prying straight up where they are connected on the board.
    FixBot'a Sor
    Yorum Ekle
  9. Punkt MP02 Screen Replacement: adım 9, 3 resimden 1. Punkt MP02 Screen Replacement: adım 9, 3 resimden 2. Punkt MP02 Screen Replacement: adım 9, 3 resimden 3.
    • Flip up the two black locking flaps securing each of the two ribbon cables.
    • Disconnect the two ribbon cables.
    FixBot'a Sor
    Yorum Ekle
  10. Punkt MP02 Screen Replacement: adım 10, 2 resimden 1. Punkt MP02 Screen Replacement: adım 10, 2 resimden 2.
    • Using your thumbs, push the board up so that the clip can slide out of the indent.
    • Use a spudger to gently separate the boards.
    • Ensure that the antennae slide through the holes—do not accidentally pull these off.
    FixBot'a Sor
    Yorum Ekle
  11. Punkt MP02 Screen Replacement: adım 11, 3 resimden 1. Punkt MP02 Screen Replacement: adım 11, 3 resimden 2. Punkt MP02 Screen Replacement: adım 11, 3 resimden 3.
    • Use a spudger to lift and disconnect the screen press connector.
    • Make sure to pry up on the edge of the connector, not the board itself.
    • Remove the screen.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Elias Fischer
425 İtibar
3 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 23
Her zaman: 103
