Ana içeriğe geç
Pyle Astro PTBL7C LCD Replacement
Neye ihtiyacın var
  1. Pyle Astro PTBL7C LCD Replacement, LCD: adım 1, 2 resimden 1. Pyle Astro PTBL7C LCD Replacement, LCD: adım 1, 2 resimden 2.
    • Using the plastic opening tool, work your way along the edge of the tablet.
    • The display is held in place by plastic tabs which slide into recesses in the rear plastic panel.
    • Once all clips are released, gently open and separate the front display assembly and the rear plastic panel.
    • Place the front display assembly facing front side down to expose the inside.
  2. Pyle Astro PTBL7C LCD Replacement: adım 2, 2 resimden 1. Pyle Astro PTBL7C LCD Replacement: adım 2, 2 resimden 2.
    • Remove the three 4 mm JIS #0 screws to release the PCB board.
  3. Pyle Astro PTBL7C LCD Replacement: adım 3, 1 resimden 1.
    • The display is held in place by plastic tabs which slide over the outer edges of the backside of the display.
    • Gently work your way around the display while pulling the plastic tabs back to release the LCD display from the front panel.
  4. Pyle Astro PTBL7C LCD Replacement: adım 4, 1 resimden 1.
    • Once all clips are released gently open and separate the front plastic display from the LCD and place the LCD face down.
    • The front plastic display contains the external touch panel, and the capacitive touch screen overlay.
  5. Pyle Astro PTBL7C LCD Replacement: adım 5, 1 resimden 1.
    • Using both hands, gently release the ribbon cable to the capacitive touch screen overlay from the PCB board by pushing both gray tabs outwards.
  6. Pyle Astro PTBL7C LCD Replacement: adım 6, 1 resimden 1.
  7. Pyle Astro PTBL7C LCD Replacement: adım 7, 1 resimden 1.
    Bu adımda kullanılan alet:
    Plastic Cards
    $2.99
    Satın Al
    • Using a plastic card, gently remove the adhesive that holds the battery in place and separate the battery from the LCD panel.
    • Exercise extreme caution and be sure to not rupture the battery casing.
  8. Pyle Astro PTBL7C LCD Replacement: adım 8, 1 resimden 1.
Sonuç
Andrew Redifer
265 İtibar
2 adet Kılavuz yazıldı
Ekip
IUPUI, Team S3-G6, Harley Spring 2018 IUPUI, Team S3-G6, Harley Spring 2018 üyesi
IUPUI-HARLEY-S18S3G6
3 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 6
Her zaman: 301
