Ana içeriğe geç
RCA RCT6272W23 Battery Replacement
Neye ihtiyacın var
    1. RCA RCT6272W23 Battery Replacement, Case: adım 1, 2 resimden 1. RCA RCT6272W23 Battery Replacement, Case: adım 1, 2 resimden 2.
      • Use a Phillips #00 screwdriver to remove both 4.1 mm screws at the top of the device which hold it together.
      FixBot'a Sor
      Yorum Ekle
    2. RCA RCT6272W23 Battery Replacement: adım 2, 2 resimden 1. RCA RCT6272W23 Battery Replacement: adım 2, 2 resimden 2.
      • Press the plastic opening tool into the space between the front and back portions of the case.
      • Run it along the perimeter of the device to unhook the plastic tabs.
      • Gently pull both sides apart.
      • The speaker is connected to the back cover, so be careful when separating.
      FixBot'a Sor
      Yorum Ekle
    1. RCA RCT6272W23 Battery Replacement, Battery: adım 3, 1 resimden 1.
      • Use a soldering iron to remove the soldered connections from the battery to the motherboard.
      • For your safety, and to ensure a correct repair, be sure to exercise caution when using the soldering iron.
      • For more information about soldering, check out this guide.
      FixBot'a Sor
      Yorum Ekle
    2. RCA RCT6272W23 Battery Replacement: adım 4, 1 resimden 1.
      • Next, use the spudger to pry the battery off of the rest of the body.
      • The battery is taped on with double-sided tape. Prepare another strip of double-sided tape and have it ready to reattach the battery.
      FixBot'a Sor
      Yorum Ekle
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Stephen Radachy
819 İtibar
5 adet Kılavuz yazıldı
Ekip
Michigan Tech, Team 1-5, Lauer Spring 2015 Michigan Tech, Team 1-5, Lauer Spring 2015 üyesi
MTU-LAUER-S15S1G5
2 Üyeler
36 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 12
Son 30 gün: 40
Her zaman: 5,778
