Ana içeriğe geç
RCA RCT6272W23 Motherboard Replacement
Neye ihtiyacın var
  1. RCA RCT6272W23 Motherboard Replacement, Case: adım 1, 2 resimden 1. RCA RCT6272W23 Motherboard Replacement, Case: adım 1, 2 resimden 2.
    • Use a Phillips #00 screwdriver to remove both 4.1 mm screws at the top of the device which hold it together.
  2. RCA RCT6272W23 Motherboard Replacement: adım 2, 2 resimden 1. RCA RCT6272W23 Motherboard Replacement: adım 2, 2 resimden 2.
    • Press the plastic opening tool into the space between the front and back portions of the case.
    • Run it along the perimeter of the device to unhook the plastic tabs.
    • Gently pull both sides apart.
    • The speaker is connected to the back cover, so be careful when separating.
  3. RCA RCT6272W23 Motherboard Replacement, Motherboard: adım 3, 3 resimden 1. RCA RCT6272W23 Motherboard Replacement, Motherboard: adım 3, 3 resimden 2. RCA RCT6272W23 Motherboard Replacement, Motherboard: adım 3, 3 resimden 3.
    • Use a soldering iron to remove the soldered connections on the motherboard
    • For your safety and to ensure a correct repair, be sure to exercise caution when using the soldering iron.
    • For more information about soldering, check out this guide.
  4. RCA RCT6272W23 Motherboard Replacement: adım 4, 1 resimden 1.
    • Use a philips #00 screwdriver to unscrew the three 4.064mm screws which attach the motherboard to the front of the device.
  5. RCA RCT6272W23 Motherboard Replacement: adım 5, 2 resimden 1. RCA RCT6272W23 Motherboard Replacement: adım 5, 2 resimden 2.
    • Use your fingers to pop the three black tabs up to release the flat plastic data transfer cables.
  6. RCA RCT6272W23 Motherboard Replacement: adım 6, 1 resimden 1.
    • Pull up the motherboard from the rest of the body.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Stephen Radachy
819 İtibar
5 adet Kılavuz yazıldı
Ekip
Michigan Tech, Team 1-5, Lauer Spring 2015 Michigan Tech, Team 1-5, Lauer Spring 2015 üyesi
MTU-LAUER-S15S1G5
2 Üyeler
12 adet Kılavuz yazıldı
Bir Yorum
i need to know everything there is about the motherboard. an tablet. images, info etc
Paul Shreves - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 3
Son 30 gün: 6
Her zaman: 2,088
