Ana içeriğe geç
RCA RCT6378W2 Battery Replacement
Neye ihtiyacın var
  1. RCA RCT6378W2 Battery Replacement, Battery: adım 1, 3 resimden 1. RCA RCT6378W2 Battery Replacement, Battery: adım 1, 3 resimden 2. RCA RCT6378W2 Battery Replacement, Battery: adım 1, 3 resimden 3.
    • Remove the two 2.4 mm x 4 mm Phillips #00 screws from the bottom of the tablet.
  2. RCA RCT6378W2 Battery Replacement: adım 2, 3 resimden 1. RCA RCT6378W2 Battery Replacement: adım 2, 3 resimden 2. RCA RCT6378W2 Battery Replacement: adım 2, 3 resimden 3.
    • Remove the back cover with a plastic opening tool, exposing the battery and motherboard.
  3. RCA RCT6378W2 Battery Replacement: adım 3, 3 resimden 1. RCA RCT6378W2 Battery Replacement: adım 3, 3 resimden 2. RCA RCT6378W2 Battery Replacement: adım 3, 3 resimden 3.
    • Remove the two black tape strips from the battery pack.
  4. RCA RCT6378W2 Battery Replacement: adım 4, 3 resimden 1. RCA RCT6378W2 Battery Replacement: adım 4, 3 resimden 2. RCA RCT6378W2 Battery Replacement: adım 4, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Remove the battery pack by carefully prying the battery back from the front cover. Then, remove the wires connecting the battery to the motherboard at the motherboard using the tweezers.
  5. RCA RCT6378W2 Battery Replacement: adım 5, 1 resimden 1.
    • Replace the damaged or malfunctioning battery with the new battery and wires. The new battery must be stuck back into its original place using thermal tape.
  6. RCA RCT6378W2 Battery Replacement: adım 6, 3 resimden 1. RCA RCT6378W2 Battery Replacement: adım 6, 3 resimden 2. RCA RCT6378W2 Battery Replacement: adım 6, 3 resimden 3.
    • The new wires must be soldered back into place on the motherboard at the original location.
    • For tips on soldering techniques, see this Soldering Guide.
Sonuç
12 farklı kişi bu kılavuzu tamamladı.
Justin
425 İtibar
2 adet Kılavuz yazıldı
Ekip
Clemson, Team 14-4, Shirley Spring 2015 Clemson, Team 14-4, Shirley Spring 2015 üyesi
CLEM-SHIRLEY-S15S14G4
6 Üyeler
15 adet Kılavuz yazıldı
7 Yorum
Links on ordering replacement batteries
Great step by step instructions not for novices!
Robert Groffel - Yanıt
i liked good job
Luis Orellana - Yanıt
Can you give information about this battery?
What type of battery is it?
Is Applicable under the Dangerous Goods Regulations?
carlos - Yanıt
where do i order the battery for RCT6378W2
Michael Giulian - Yanıt
RCT6378W2 where can i get a replacement battery
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 32
Her zaman: 27,031
