Ana içeriğe geç
Raptor 2 / T REX 3 Y End Stop Adaptor
Neye ihtiyacın var
  1. Raptor 2 / T REX 3 Y End Stop Adaptor, Y End Stop Adaptor: adım 1, 3 resimden 1. Raptor 2 / T REX 3 Y End Stop Adaptor, Y End Stop Adaptor: adım 1, 3 resimden 2. Raptor 2 / T REX 3 Y End Stop Adaptor, Y End Stop Adaptor: adım 1, 3 resimden 3.
    • Retain all fasteners until after assembly.
    • Find the file for printing at http://bit.ly/2RFHGyT
    • To start this process, you will need to remove all 4 corner leveling knobs. There may also be a star washer between the knob and Y carriage plate on each corner.
    • The screw that is not allowing the new chain to sit flat, needs to be removed. Use an M2.5 hex for this.
    • The screw is no longer needed.
    • The raised part sits closer to one side. It should face the end stop.
    • Test fit the printed part first to make sure it sits all the way flush.
  2. Raptor 2 / T REX 3 Y End Stop Adaptor, Y End Stop Adaptor: adım 2, 3 resimden 1. Raptor 2 / T REX 3 Y End Stop Adaptor, Y End Stop Adaptor: adım 2, 3 resimden 2. Raptor 2 / T REX 3 Y End Stop Adaptor, Y End Stop Adaptor: adım 2, 3 resimden 3.
    • Loosen the socket head screw using a M4 hex .
    • Reposition the end stop so that the new printed part triggers the lever.
    • Using a RTV silicone based adhesive (high temp suggested) or another glue that works with plastic/metal, apply a small amount of glue to the sides of the printed part on the inside corner.
  3. Raptor 2 / T REX 3 Y End Stop Adaptor, Y End Stop Adaptor: adım 3, 2 resimden 1. Raptor 2 / T REX 3 Y End Stop Adaptor, Y End Stop Adaptor: adım 3, 2 resimden 2.
    • Clean up any excess glue using a paper towel.
    • Double check that the end stop is triggered by the new part. Reposition the end stop bracket if necessary.
    • Tighten the end stop bracket.
    • This is held in with a bolt and T Nut. Make sure the bracket is secure after tightening the bolt.
    • Continue on with Step 10 on the Cable Chain Install Guide by clicking http://bit.ly/2Runj7r.
Sonuç
Tiny Machines 3D
3.019 İtibar
14 adet Kılavuz yazıldı
Ekip
Tiny Machines 3D Tiny Machines 3D üyesi
Community
5 Üyeler
41 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 4
Her zaman: 159
