Ana içeriğe geç
Razer Basilisk V3 Scroll Wheel Assembly Replacement
Neye ihtiyacın var
  1. Razer Basilisk V3 Scroll Wheel Assembly Replacement, Skates: adım 1, 1 resimden 1.
    • Locate each of the skates.
  2. Razer Basilisk V3 Scroll Wheel Assembly Replacement: adım 2, 3 resimden 1. Razer Basilisk V3 Scroll Wheel Assembly Replacement: adım 2, 3 resimden 2. Razer Basilisk V3 Scroll Wheel Assembly Replacement: adım 2, 3 resimden 3.
    • Heat the skate using a heat gun or hair dryer.
    • Using the pointy end of the spudger pry away a corner of the skate.
    • If the adhesive does not pull away easily, heat the skate more.
    • Once the corner of the skate comes free use the flat end of the spudger to peel off the rest of the skate.
    • Repeat these steps for each of the skates.
  3. Razer Basilisk V3 Scroll Wheel Assembly Replacement, Backplate: adım 3, 1 resimden 1.
    • Remove two 4.8 mm screws that were hidden under the skates using a JIS #1 screwdriver.
    • Remove the single 4 mm screw beneath the thumb grip using a JIS #1 screwdriver.
  4. Razer Basilisk V3 Scroll Wheel Assembly Replacement: adım 4, 3 resimden 1. Razer Basilisk V3 Scroll Wheel Assembly Replacement: adım 4, 3 resimden 2. Razer Basilisk V3 Scroll Wheel Assembly Replacement: adım 4, 3 resimden 3.
    • Heat the label gently with a heat gun or hair dryer.
    • Once the adhesive is loosened, use a spudger to peel off the label carefully, revealing two additional screws.
    • Remove the two 4.8 mm screws using a JIS #1 screwdriver.
  5. Razer Basilisk V3 Scroll Wheel Assembly Replacement: adım 5, 3 resimden 1. Razer Basilisk V3 Scroll Wheel Assembly Replacement: adım 5, 3 resimden 2. Razer Basilisk V3 Scroll Wheel Assembly Replacement: adım 5, 3 resimden 3.
    • Carefully pry apart the mouse's top and bottom halves. Using the iFixit opening tool, start at one corner and work around the edge.
    • Be cautious of the clips that may break during this process.
    • Using a plastic opening tool, gently pry the connector apart by moving side to side to avoid bending the pins.
    • When reassembling, be mindful that the connector only fits one way, as shown in the pictures.
  6. Razer Basilisk V3 Scroll Wheel Assembly Replacement, Scroll Wheel Assembly: adım 6, 3 resimden 1. Razer Basilisk V3 Scroll Wheel Assembly Replacement, Scroll Wheel Assembly: adım 6, 3 resimden 2. Razer Basilisk V3 Scroll Wheel Assembly Replacement, Scroll Wheel Assembly: adım 6, 3 resimden 3.
    • Use the flat end of the spudger to pop-out the scroll wheel assembly.
    • Make sure you are careful when removing the assembly since it is still connected to the device with a ribbon cable. If you pull too hard the cable could break.
  7. Razer Basilisk V3 Scroll Wheel Assembly Replacement: adım 7, 3 resimden 1. Razer Basilisk V3 Scroll Wheel Assembly Replacement: adım 7, 3 resimden 2. Razer Basilisk V3 Scroll Wheel Assembly Replacement: adım 7, 3 resimden 3.
    • Pull up on the top half of the cable connector and pull the cable from the connector.
    • The connection pins on the wire face towards the scroll wheel assembly housing. When reassembling, make sure the connectors on the cable are facing the correct direction.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Mary Quin
252 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-2, Santin Spring 2024 UMass Dartmouth, Team 1-2, Santin Spring 2024 üyesi
UMASSD-SANTIN-S24S1G2
3 Üyeler
11 adet Kılavuz yazıldı
1Rehber Yorum
Where can I buy this complete spare part?
Van4ESss - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 19
Son 7 gün: 89
Son 30 gün: 367
Her zaman: 2,533
