Ana içeriğe geç
Razer BlackShark V2 Ear Cushion Replacement
Neye ihtiyacın var
  1. Razer BlackShark V2 Ear Cushion Replacement, Ear Cushion: adım 1, 1 resimden 1.
    • Place the headset so that the left side is facing you.
    • The left side of the headset has the cable attachment and the volume control knob.
  2. Razer BlackShark V2 Ear Cushion Replacement: adım 2, 1 resimden 1.
    • Scoop your middle and ring finger underneath the top or bottom inner portion of the ear cushion.
    • You should feel a hard plastic ridge.
    • Pull from the hard plastic ridge, being sure not to pull from the soft cushion.
    • Slowly apply pressure to prevent damage.
  3. Razer BlackShark V2 Ear Cushion Replacement: adım 3, 1 resimden 1.
  4. Razer BlackShark V2 Ear Cushion Replacement: adım 4, 2 resimden 1. Razer BlackShark V2 Ear Cushion Replacement: adım 4, 2 resimden 2.
    • Once the cushion is removed, make sure the hard plastic base with the clips is attached to it.
    • If you are replacing both ear cushions, repeat Steps 1-4 for the other side. Then, insert the new ear cushions by lining up the clips in their respective holes and applying even pressure until they audibly click.
Bitiş Çizgisi
Bir başkası bu kılavuzu tamamladı.
BlakeB
470 İtibar
3 adet Kılavuz yazıldı
2 Yorum
Thanks - this was very helpful. It was difficult to remove the retainer clip using my fingers - I found it much easier to use the back of a spoon (with a rounded edge) and getting more leverage that way.
Peter Gu - Yanıt
can someone pls tell me what's the size or mm of the foam?
Lorraine Corda - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 24
Son 30 gün: 167
Her zaman: 1,769
