Giriş
If your Razer BlackShark V2 foam ear cushions are shedding particles or detaching from the device (Razer Blackshark V2 Troubleshooting Page, "Ear Cushions Falling Apart"), this guide will assist you in their replacement. Be sure to be mindful of which layer of the headset assembly you're taking apart and that you don't adversely damage any holds, the rubber lining under the cushions, or the headset itself when applying pressure.
Neye ihtiyacın var
Bir başkası bu kılavuzu tamamladı.
2 Yorum
can someone pls tell me what's the size or mm of the foam?
