Ana içeriğe geç
Razer Blade 15" (2018) RAM Replacement
Neye ihtiyacın var
  1. Razer Blade 15" (2018) RAM Replacement, Prepare your laptop for disassembly: adım 1, 2 resimden 1. Razer Blade 15" (2018) RAM Replacement, Prepare your laptop for disassembly: adım 1, 2 resimden 2.
    • Allow your laptop's battery to drain below 25% before starting this repair—a charged battery may catch fire if damaged.
    • Unplug all cables, fully shut down your laptop, and close the lid.
  2. Razer Blade 15" (2018) RAM Replacement, Unfasten the back cover: adım 2, 1 resimden 1.
    • Rotate your laptop so the screen hinge is farthest from you.
    • Use a Torx T5 driver to remove the ten 3.8 mm-long screws securing the back cover.
  3. Razer Blade 15" (2018) RAM Replacement, Insert an opening pick: adım 3, 3 resimden 1. Razer Blade 15" (2018) RAM Replacement, Insert an opening pick: adım 3, 3 resimden 2. Razer Blade 15" (2018) RAM Replacement, Insert an opening pick: adım 3, 3 resimden 3.
    • Depending on the age and condition of your laptop, the back cover may come off sooner than this guide instructs. If the cover feels loose, remove it at any time.
    • Apply a suction handle to the right edge of the back cover, between the middle screws and the screws closest to you.
    • Pull up on the suction handle to create a small gap between the back cover and the frame.
    • Insert an opening pick into the gap.
  4. Razer Blade 15" (2018) RAM Replacement, Angle the opening pick: adım 4, 3 resimden 1. Razer Blade 15" (2018) RAM Replacement, Angle the opening pick: adım 4, 3 resimden 2. Razer Blade 15" (2018) RAM Replacement, Angle the opening pick: adım 4, 3 resimden 3.
    • Angle your opening pick upward, away from the frame. Keep it angled upward as long as it's between the back cover and the frame.
    • Insert your pick up to 10 mm (0.4 in) deep.
  5. Razer Blade 15" (2018) RAM Replacement, Free the bottom right corner: adım 5, 3 resimden 1. Razer Blade 15" (2018) RAM Replacement, Free the bottom right corner: adım 5, 3 resimden 2. Razer Blade 15" (2018) RAM Replacement, Free the bottom right corner: adım 5, 3 resimden 3.
    • Slide your opening pick around the bottom right corner of the back cover to free it from the frame.
  6. Razer Blade 15" (2018) RAM Replacement, Free the front edge: adım 6, 3 resimden 1. Razer Blade 15" (2018) RAM Replacement, Free the front edge: adım 6, 3 resimden 2. Razer Blade 15" (2018) RAM Replacement, Free the front edge: adım 6, 3 resimden 3.
    • Slide your opening pick along the front edge and around the front left corner of the back cover to free it from the frame.
  7. Razer Blade 15" (2018) RAM Replacement, Remove the back cover: adım 7, 3 resimden 1. Razer Blade 15" (2018) RAM Replacement, Remove the back cover: adım 7, 3 resimden 2. Razer Blade 15" (2018) RAM Replacement, Remove the back cover: adım 7, 3 resimden 3.
    • Remove the back cover.
    • Lay the back cover down on its rubber feet to avoid damaging the gray thermal pads on its underside.
  8. Razer Blade 15" (2018) RAM Replacement, Soften the battery cable tape adhesive: adım 8, 2 resimden 1. Razer Blade 15" (2018) RAM Replacement, Soften the battery cable tape adhesive: adım 8, 2 resimden 2.
    • Apply a heated iOpener to the battery cable tape for one minute.
    • You can also use a hair dryer—but be careful, as overheating the battery may damage it or create a fire hazard.
  9. Razer Blade 15" (2018) RAM Replacement, Peel up the battery cable tape: adım 9, 3 resimden 1. Razer Blade 15" (2018) RAM Replacement, Peel up the battery cable tape: adım 9, 3 resimden 2. Razer Blade 15" (2018) RAM Replacement, Peel up the battery cable tape: adım 9, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Be careful not to damage the battery with your tool.
    • Use blunt nose tweezers or your fingers to peel the battery cable tape away from the cable.
  10. Razer Blade 15" (2018) RAM Replacement, Disconnect the battery: adım 10, 3 resimden 1. Razer Blade 15" (2018) RAM Replacement, Disconnect the battery: adım 10, 3 resimden 2. Razer Blade 15" (2018) RAM Replacement, Disconnect the battery: adım 10, 3 resimden 3.
    • Use the point of a spudger to press on alternating sides of the battery connector and walk it out of its socket.
  11. Razer Blade 15" (2018) RAM Replacement, Remove the lower RAM stick: adım 11, 3 resimden 1. Razer Blade 15" (2018) RAM Replacement, Remove the lower RAM stick: adım 11, 3 resimden 2. Razer Blade 15" (2018) RAM Replacement, Remove the lower RAM stick: adım 11, 3 resimden 3.
    • Two metal arms secure the left and right edges of each RAM stick.
    • Push the lower RAM stick's metal arms outward to disengage them.
    • Remove the RAM stick.
    • During reassembly, insert the RAM stick at a 30-degree angle, then push straight down to engage the metal arms.
  12. Razer Blade 15" (2018) RAM Replacement, Remove the upper RAM stick: adım 12, 3 resimden 1. Razer Blade 15" (2018) RAM Replacement, Remove the upper RAM stick: adım 12, 3 resimden 2. Razer Blade 15" (2018) RAM Replacement, Remove the upper RAM stick: adım 12, 3 resimden 3.
    • Disengage the upper RAM stick's arms and remove the RAM.
Sonuç
Clay Eickemeyer
82.294 İtibar
455 adet Kılavuz yazıldı
Ekip
Guide Team Guide Team üyesi
Staff
9 Üyeler
11.499 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 12
Her zaman: 313
