Ana içeriğe geç
Razer Blade 15" (2020) Left Fan Replacement
Neye ihtiyacın var
  1. Razer Blade 15" (2020) Left Fan Replacement, Prepare your laptop for disassembly: adım 1, 2 resimden 1. Razer Blade 15" (2020) Left Fan Replacement, Prepare your laptop for disassembly: adım 1, 2 resimden 2.
    • Allow your laptop's battery to drain below 25% before starting this repair—a charged battery may catch fire if damaged.
    • Unplug all cables and fully shut down your laptop.
    • Close the lid and flip your laptop over so the back cover faces up.
  2. Razer Blade 15" (2020) Left Fan Replacement, Unfasten the back cover: adım 2, 1 resimden 1.
    • Use a T5 Torx driver to remove the ten 3.7 mm-long screws securing the back cover.
  3. Razer Blade 15" (2020) Left Fan Replacement, Loosen the back cover: adım 3, 3 resimden 1. Razer Blade 15" (2020) Left Fan Replacement, Loosen the back cover: adım 3, 3 resimden 2. Razer Blade 15" (2020) Left Fan Replacement, Loosen the back cover: adım 3, 3 resimden 3.
    • The back cover is lightly secured to the motherboard by thermal pads. Depending on the age of your laptop, it may be easier or harder to remove.
    • Use a finger to pry up the right side of the back cover, starting at the Ethernet port cutout.
  4. Razer Blade 15" (2020) Left Fan Replacement, Remove the back cover: adım 4, 3 resimden 1. Razer Blade 15" (2020) Left Fan Replacement, Remove the back cover: adım 4, 3 resimden 2. Razer Blade 15" (2020) Left Fan Replacement, Remove the back cover: adım 4, 3 resimden 3.
    • Remove the back cover slowly, as to avoid tearing the thermal pads underneath.
    • Lay the back cover down on its rubber feet to avoid damaging the thermal pads on its underside.
  5. Razer Blade 15" (2020) Left Fan Replacement, Soften the battery cable tape adhesive: adım 5, 2 resimden 1. Razer Blade 15" (2020) Left Fan Replacement, Soften the battery cable tape adhesive: adım 5, 2 resimden 2.
    • Apply a heated iOpener to the battery cable tape for one minute.
    • You can also use a hair dryer—but be careful, as overheating the battery may damage it or cause a fire.
  6. Razer Blade 15" (2020) Left Fan Replacement, Remove the battery cable tape: adım 6, 3 resimden 1. Razer Blade 15" (2020) Left Fan Replacement, Remove the battery cable tape: adım 6, 3 resimden 2. Razer Blade 15" (2020) Left Fan Replacement, Remove the battery cable tape: adım 6, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Be careful not to damage the battery with your tool.
    • Use blunt nose tweezers or your fingers to peel and remove the battery cable tape.
  7. Razer Blade 15" (2020) Left Fan Replacement, Disconnect the battery: adım 7, 2 resimden 1. Razer Blade 15" (2020) Left Fan Replacement, Disconnect the battery: adım 7, 2 resimden 2.
    • Use the flat end of a spudger to push the square tab on the battery connector and slide it out of its socket.
  8. Razer Blade 15" (2020) Left Fan Replacement, Label the antenna cables: adım 8, 2 resimden 1. Razer Blade 15" (2020) Left Fan Replacement, Label the antenna cables: adım 8, 2 resimden 2.
    • In the next two steps, you'll disconnect the Wi-Fi antenna cables to access other components.
    • The antenna cables look very similar. Label one of them with a piece of tape or marker and remember which socket it connects to.
  9. Razer Blade 15" (2020) Left Fan Replacement, Disconnect the antenna cables: adım 9, 3 resimden 1. Razer Blade 15" (2020) Left Fan Replacement, Disconnect the antenna cables: adım 9, 3 resimden 2. Razer Blade 15" (2020) Left Fan Replacement, Disconnect the antenna cables: adım 9, 3 resimden 3.
    $3.99
    • Insert one arm of angled tweezers under the metal neck of each antenna cable and pry up to disconnect it.
    • During reassembly, align the connector over its socket and gently press down with the flat end of your spudger or your fingernail until it clicks into place.
  10. Razer Blade 15" (2020) Left Fan Replacement, Disconnect the screen press connector: adım 10, 2 resimden 1. Razer Blade 15" (2020) Left Fan Replacement, Disconnect the screen press connector: adım 10, 2 resimden 2.
    • Grab the pull tab on the screen connector.
    • Pull up to disconnect the connector from its socket.
    • During reassembly, align the connector over its socket and press down until it clicks into place.
  11. Razer Blade 15" (2020) Left Fan Replacement, Disconnect the charging port: adım 11, 3 resimden 1. Razer Blade 15" (2020) Left Fan Replacement, Disconnect the charging port: adım 11, 3 resimden 2. Razer Blade 15" (2020) Left Fan Replacement, Disconnect the charging port: adım 11, 3 resimden 3.
    • Use the point of your spudger to press on alternating sides of the charging port connector to "walk" it out of its socket.
  12. Razer Blade 15" (2020) Left Fan Replacement, Move the charging cable: adım 12, 2 resimden 1. Razer Blade 15" (2020) Left Fan Replacement, Move the charging cable: adım 12, 2 resimden 2.
    • Move the charging cable over the right edge of the laptop.
  13. Razer Blade 15" (2020) Left Fan Replacement, Move the screen and antenna cables: adım 13, 3 resimden 1. Razer Blade 15" (2020) Left Fan Replacement, Move the screen and antenna cables: adım 13, 3 resimden 2. Razer Blade 15" (2020) Left Fan Replacement, Move the screen and antenna cables: adım 13, 3 resimden 3.
    • Unclip the screen and antenna cables from the fan and move them over the right edge of the laptop.
  14. Razer Blade 15" (2020) Left Fan Replacement, Disconnect the left fan: adım 14, 2 resimden 1. Razer Blade 15" (2020) Left Fan Replacement, Disconnect the left fan: adım 14, 2 resimden 2.
    • Use tweezers or your fingers to grab the rubber sleeve around the left fan cable and pull the connector straight out of its socket.
  15. Razer Blade 15" (2020) Left Fan Replacement, Unfasten the left fan: adım 15, 1 resimden 1.
    • Use a Phillips screwdriver to remove the two 6.7 mm screws securing the left fan.
  16. Razer Blade 15" (2020) Left Fan Replacement, Remove the left fan: adım 16, 2 resimden 1. Razer Blade 15" (2020) Left Fan Replacement, Remove the left fan: adım 16, 2 resimden 2.
    • Remove the left fan.
Sonuç
Clay Eickemeyer
82.642 İtibar
455 adet Kılavuz yazıldı
Ekip
Guide Team Guide Team üyesi
Staff
9 Üyeler
11.545 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 19
Her zaman: 511
