Ana içeriğe geç
Razer Blade 15" (2020) SSD Replacement
Neye ihtiyacın var
  1. Razer Blade 15" (2020) SSD Replacement, Prepare your laptop for disassembly: adım 1, 2 resimden 1. Razer Blade 15" (2020) SSD Replacement, Prepare your laptop for disassembly: adım 1, 2 resimden 2.
    • Allow your laptop's battery to drain below 25% before starting this repair—a charged battery may catch fire if damaged.
    • Unplug all cables and fully shut down your laptop.
    • Close the lid and flip your laptop over so the back cover faces up.
  2. Razer Blade 15" (2020) SSD Replacement, Unfasten the back cover: adım 2, 1 resimden 1.
    • Use a T5 Torx driver to remove the ten 3.7 mm-long screws securing the back cover.
  3. Razer Blade 15" (2020) SSD Replacement, Loosen the back cover: adım 3, 3 resimden 1. Razer Blade 15" (2020) SSD Replacement, Loosen the back cover: adım 3, 3 resimden 2. Razer Blade 15" (2020) SSD Replacement, Loosen the back cover: adım 3, 3 resimden 3.
    • The back cover is lightly secured to the motherboard by thermal pads. Depending on the age of your laptop, it may be easier or harder to remove.
    • Use a finger to pry up the right side of the back cover, starting at the Ethernet port cutout.
  4. Razer Blade 15" (2020) SSD Replacement, Remove the back cover: adım 4, 3 resimden 1. Razer Blade 15" (2020) SSD Replacement, Remove the back cover: adım 4, 3 resimden 2. Razer Blade 15" (2020) SSD Replacement, Remove the back cover: adım 4, 3 resimden 3.
    • Remove the back cover slowly, as to avoid tearing the thermal pads underneath.
    • Lay the back cover down on its rubber feet to avoid damaging the thermal pads on its underside.
  5. Razer Blade 15" (2020) SSD Replacement, Soften the battery cable tape adhesive: adım 5, 2 resimden 1. Razer Blade 15" (2020) SSD Replacement, Soften the battery cable tape adhesive: adım 5, 2 resimden 2.
    • Apply a heated iOpener to the battery cable tape for one minute.
    • You can also use a hair dryer—but be careful, as overheating the battery may damage it or cause a fire.
  6. Razer Blade 15" (2020) SSD Replacement, Remove the battery cable tape: adım 6, 3 resimden 1. Razer Blade 15" (2020) SSD Replacement, Remove the battery cable tape: adım 6, 3 resimden 2. Razer Blade 15" (2020) SSD Replacement, Remove the battery cable tape: adım 6, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Be careful not to damage the battery with your tool.
    • Use blunt nose tweezers or your fingers to peel and remove the battery cable tape.
  7. Razer Blade 15" (2020) SSD Replacement, Disconnect the battery: adım 7, 2 resimden 1. Razer Blade 15" (2020) SSD Replacement, Disconnect the battery: adım 7, 2 resimden 2.
    • Use the flat end of a spudger to push the square tab on the battery connector and slide it out of its socket.
  8. Razer Blade 15" (2020) SSD Replacement, Unfasten the SSD: adım 8, 3 resimden 1. Razer Blade 15" (2020) SSD Replacement, Unfasten the SSD: adım 8, 3 resimden 2. Razer Blade 15" (2020) SSD Replacement, Unfasten the SSD: adım 8, 3 resimden 3.
    • Use a Phillips screwdriver to remove the 3.1 mm screw securing the SSD.
    • The SSD will pop up slightly.
  9. Razer Blade 15" (2020) SSD Replacement, Remove the SSD: adım 9, 3 resimden 1. Razer Blade 15" (2020) SSD Replacement, Remove the SSD: adım 9, 3 resimden 2. Razer Blade 15" (2020) SSD Replacement, Remove the SSD: adım 9, 3 resimden 3.
    • Pull the SSD straight out of its socket and remove it.
    • During reassembly, insert the SSD at a slight downward angle before lowering it flat to the frame and securing it with its screw.
Sonuç
Clay Eickemeyer
82.297 İtibar
455 adet Kılavuz yazıldı
Ekip
Guide Team Guide Team üyesi
Staff
9 Üyeler
11.499 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 22
Her zaman: 623
