Ana içeriğe geç
Razer Deathadder Elite Scroll Wheel Replacement
Neye ihtiyacın var
  1. Razer Deathadder Elite Scroll Wheel Replacement, Scroll Wheel: adım 1, 2 resimden 1. Razer Deathadder Elite Scroll Wheel Replacement, Scroll Wheel: adım 1, 2 resimden 2.
    • Pry the skate off the two upper screws.
    • Remove the two upper screws using a Phillips #00 screwdriver.
    • Poke a hole with your screwdriver into the product sticker on the bottom of the mouse.
    • Remove the bottom screw using a Phillips #00 screwdriver.
  2. Razer Deathadder Elite Scroll Wheel Replacement: adım 2, 2 resimden 1. Razer Deathadder Elite Scroll Wheel Replacement: adım 2, 2 resimden 2.
    • Lift up the upper shell of the mouse.
    • Use caution; the shell if still connected to the base.
    • Detach the two wired connectors from the circuit board.
  3. Razer Deathadder Elite Scroll Wheel Replacement: adım 3, 3 resimden 1. Razer Deathadder Elite Scroll Wheel Replacement: adım 3, 3 resimden 2. Razer Deathadder Elite Scroll Wheel Replacement: adım 3, 3 resimden 3.
    • Unscrew the scroll wheel LED.
    • Carefully remove the scroll wheel.
    I followed this tutorial for a Razer Deathadder Essential, so that I could fix a jumpy scroll wheel. To remove the scroll wheel, I had to remove the two screws that held the board into the mouse housing. This allows you to lift the board up and out of the black frame pieces that hold the scroll wheel in place.
    Chris Schnabel - Yanıt
  4. Razer Deathadder Elite Scroll Wheel Replacement: adım 4, 1 resimden 1.
    • Insert the replacement wheel into the mouse.
    If you are trying to fix a jumpy scroll wheel, you should also clean the encoder. This is the round piece component that the scroll wheel is inserted into. To do this, you can pry open the four metal fingers, bend back the metal backing, and then the encoder ring will come right off. In my case a hair fell out, but I also cleaned with some isopropyl alcohol which picked up some grime.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Hamilton Liu
214 İtibar
1 Kılavuz yazıldı
Ekip
Bir Yorum
Hi! What size and manufacturer is the encoder in this mouse?
m2l2kopower - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 54
Son 30 gün: 347
Her zaman: 4,898
