Ana içeriğe geç
Razer Deathadder Essential RZ01-0254 Mouse Buttons Replacement
Neye ihtiyacın var
  1. Razer Deathadder Essential RZ01-0254 Mouse Buttons Replacement, Mouse Buttons: adım 1, 2 resimden 1. Razer Deathadder Essential RZ01-0254 Mouse Buttons Replacement, Mouse Buttons: adım 1, 2 resimden 2.
    • Use a spudger or opening tool to remove the top skates from the mouse.
    • Poke a hole in the middle of the bar code to expose the 3 screws holding the mouse together.
  2. Razer Deathadder Essential RZ01-0254 Mouse Buttons Replacement: adım 2, 1 resimden 1.
    • Use a Phillips #1 screwdriver to remove the three 9 mm screws that are holding the mouse together.
  3. Razer Deathadder Essential RZ01-0254 Mouse Buttons Replacement: adım 3, 3 resimden 1. Razer Deathadder Essential RZ01-0254 Mouse Buttons Replacement: adım 3, 3 resimden 2. Razer Deathadder Essential RZ01-0254 Mouse Buttons Replacement: adım 3, 3 resimden 3.
    • Open the mouse, and use the Phillips #1 screwdriver remove the two 11 mm screws that are located on the left side of the motherboard.
    • Also, remove the single 4 mm screw next to the mouse wheel using the Phillips #1 screwdriver.
    • After you remove all three screws the motherboard should be free.
  4. Razer Deathadder Essential RZ01-0254 Mouse Buttons Replacement: adım 4, 2 resimden 1. Razer Deathadder Essential RZ01-0254 Mouse Buttons Replacement: adım 4, 2 resimden 2.
    • This is the component that we will be replacing and its 3 contact points.
  5. Razer Deathadder Essential RZ01-0254 Mouse Buttons Replacement: adım 5, 1 resimden 1.
    Bu adımda kullanılan alet:
    Desoldering Pump
    $3.99
    Satın Al
    • Using your soldering iron and desoldering pump, desolder the 3 contact points that attach to each button as marked.
    • Be careful when using a soldering iron, as it can burn you if not used correctly.
  6. Razer Deathadder Essential RZ01-0254 Mouse Buttons Replacement: adım 6, 3 resimden 1. Razer Deathadder Essential RZ01-0254 Mouse Buttons Replacement: adım 6, 3 resimden 2. Razer Deathadder Essential RZ01-0254 Mouse Buttons Replacement: adım 6, 3 resimden 3.
    • Remove the button that you just desoldered.
    • Then solder the new button back into place. Repeat for both buttons.
  7. Razer Deathadder Essential RZ01-0254 Mouse Buttons Replacement: adım 7, 3 resimden 1. Razer Deathadder Essential RZ01-0254 Mouse Buttons Replacement: adım 7, 3 resimden 2. Razer Deathadder Essential RZ01-0254 Mouse Buttons Replacement: adım 7, 3 resimden 3.
    • Return the motherboard to its original position, and replace the two 11 mm screws and the single 4 mm screw using a Phillips #1 screwdriver.
  8. Razer Deathadder Essential RZ01-0254 Mouse Buttons Replacement: adım 8, 1 resimden 1.
    • Close up the mouse, and replace the three 9 mm using a Phillips #1 screwdriver.
  9. Razer Deathadder Essential RZ01-0254 Mouse Buttons Replacement: adım 9, 1 resimden 1.
    • Finally, replace the skates and you are finished.
Bitiş Çizgisi
5 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
you helped me a lot
Gustavo Melo Santos - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 9
Son 7 gün: 64
Son 30 gün: 299
Her zaman: 6,819
