Ana içeriğe geç
Razer Kraken 7.1 Chroma Speaker Casing Replacement
Neye ihtiyacın var
  1. Razer Kraken 7.1 Chroma Speaker Casing Replacement, Ear Cushion: adım 1, 1 resimden 1.
    • Grab the ear cushion between your thumb and forefinger.
  2. Razer Kraken 7.1 Chroma Speaker Casing Replacement: adım 2, 1 resimden 1.
    • Pull the ear cushion away from the speaker by sliding down to release the cushion from the plastic covering.
  3. Razer Kraken 7.1 Chroma Speaker Casing Replacement: adım 3, 1 resimden 1.
    • Continue sliding downwards around all edges of the ear cushion until the cushion is fully removed.
  4. Razer Kraken 7.1 Chroma Speaker Casing Replacement, Speaker: adım 4, 3 resimden 1. Razer Kraken 7.1 Chroma Speaker Casing Replacement, Speaker: adım 4, 3 resimden 2. Razer Kraken 7.1 Chroma Speaker Casing Replacement, Speaker: adım 4, 3 resimden 3.
    • Use the broad edge of the plastic spudger and a lot of force to pop off the speaker from the headset.
    • Insert the plastic spudger in between the speaker and the headset directly in line with one of the exposed screws of the headset casing, since that is where the four clamps that hold the speaker to the headset are located. These clamps are not visible until after speaker removal.
    • Make sure to insert the spudger in between the foam buffer-ring and the headset casing instead of in between the speaker and the foam buffer-ring.
    • Reassembly may be tricky, there is one clamp smaller than others, so you have to align it correctly.
  5. Razer Kraken 7.1 Chroma Speaker Casing Replacement: adım 5, 1 resimden 1.
    • Cut both wires connecting the speaker to the headset by using a wire stripper or pair of scissors.
    • Cut as close as possible to the connections on the speaker circuit board.
  6. Razer Kraken 7.1 Chroma Speaker Casing Replacement, Speaker Casing: adım 6, 2 resimden 1. Razer Kraken 7.1 Chroma Speaker Casing Replacement, Speaker Casing: adım 6, 2 resimden 2.
    • Use the Phillips #00 screwdriver to remove all four 9mm screws.
    • Rotate the screwdriver counterclockwise when removing each screw.
  7. Razer Kraken 7.1 Chroma Speaker Casing Replacement: adım 7, 3 resimden 1. Razer Kraken 7.1 Chroma Speaker Casing Replacement: adım 7, 3 resimden 2. Razer Kraken 7.1 Chroma Speaker Casing Replacement: adım 7, 3 resimden 3.
    • Pull the casing upwards to remove it from the headset.
    • If you are removing the casing on the side of the microphone, slide the casing towards you along the length of the microphone until the casing is completely removed.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Karissa Sealey
995 İtibar
4 adet Kılavuz yazıldı
Ekip
Baylor, Team S5-G3, Williams Spring 2017 Baylor, Team S5-G3, Williams Spring 2017 üyesi
BU-WILLIAMS-S17S5G3
3 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 27
Her zaman: 5,172
