Giriş
Before accessing the speaker casing, you need to remove the ear cushion. The casing of the speaker could be damaged by dropping the headset, but can easily be replaced by following the steps provided. The wires will have to be soldered during the reassembly process.
Neye ihtiyacın var
Use the broad edge of the plastic spudger and a lot of force to pop off the speaker from the headset.
Use the Phillips #00 screwdriver to remove all four 9mm screws.
Rotate the screwdriver counterclockwise when removing each screw.
2 farklı kişi bu kılavuzu tamamladı.
