Ana içeriğe geç
Razer Naga 2014 (Left-Handed Edition) Scroll Wheel Encoder Replacement
Tony Di Folca
Tony Di Folca ve başka bir katkıda bulunan
En son June 2, 2021 tarihinde güncellendi
10 - 20 dakika
Orta
Öne Çıkan Öğrenci Kılavuzu
A faulty scroll wheel encoder chip will cause irregular scrolling. You can replace the chip and still preserve the stock wheel and lights if you follow this guide. Also make sure that the mouse is unplugged from the pc prior to beginning.
The Razer Naga 2014 (Left-Handed Edition) was discontinued from production shortly after it’s initial run. Unfortunately for many people, including myself, using a standard right handed mouse is not an option. So this guide will help people preserve their mouse and use it for years to come.
Neye ihtiyacın var
Parçalar
Aletler
  • Phillips #00 Screwdriver
  • Spudger
    Spudger
Daha fazlasını göster…
iFixit bu bağlantılar üzerinden satın aldığınızda komisyon kazanır.
  1. Razer Naga 2014 (Left-Handed Edition) Scroll Wheel Encoder Replacement, Scroll Wheel Encoder: adım 1, 1 resimden 1.
    • Peel back the two teflon pads from the top corners and the one larger one from the bottom with the help of a spudger.
    • You will find four 7 mm screws under the teflon pads.
  2. Razer Naga 2014 (Left-Handed Edition) Scroll Wheel Encoder Replacement: adım 2, 1 resimden 1.
    • Remove the four 7mm screws using a Phillips #00 screwdriver.
  3. Razer Naga 2014 (Left-Handed Edition) Scroll Wheel Encoder Replacement: adım 3, 2 resimden 1. Razer Naga 2014 (Left-Handed Edition) Scroll Wheel Encoder Replacement: adım 3, 2 resimden 2.
    • Gently remove the top plastic shell from the mouse.
    • Be careful when lifting the shell up to avoid damage to the cable connected to the board and shell.
    • The top shell is separate from the sides of the mouse.
    • Unplug the cable coming from the top shell that connects to the board.
  4. Razer Naga 2014 (Left-Handed Edition) Scroll Wheel Encoder Replacement: adım 4, 1 resimden 1.
    • Gently pull the two plastic sides off the mouse.
    • Pry the sides off gently so you don't crack any of the plastic tabs that hold them in place.
  5. Razer Naga 2014 (Left-Handed Edition) Scroll Wheel Encoder Replacement: adım 5, 1 resimden 1.
    • Use a Phillips #00 screwdriver to remove the 5 mm screw holding the scroll wheel in place.
    • This screw is different than the ones at the bottom of the mouse so keep it separate.
  6. Razer Naga 2014 (Left-Handed Edition) Scroll Wheel Encoder Replacement: adım 6, 1 resimden 1.
    • Unplug the cord that connects the scroll wheel to the motherboard.
  7. Razer Naga 2014 (Left-Handed Edition) Scroll Wheel Encoder Replacement: adım 7, 1 resimden 1.
    • Gently slide the lighting chip up and out of the scroll wheel.
  8. Razer Naga 2014 (Left-Handed Edition) Scroll Wheel Encoder Replacement: adım 8, 1 resimden 1.
    • Use a spudger to gently pry the scroll wheel assembly out from the plastic housing.
  9. Razer Naga 2014 (Left-Handed Edition) Scroll Wheel Encoder Replacement: adım 9, 1 resimden 1.
    • Remove the scroll wheel from the holder by pushing it up from underneath.
  10. Razer Naga 2014 (Left-Handed Edition) Scroll Wheel Encoder Replacement: adım 10, 1 resimden 1.
    • Remove the old encoder chip and replace with the new one.
    • Make sure that the silver part of the encoder faces out and that the small square points down when reinstalling.
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 13
Son 30 gün: 73
Her zaman: 2,136
