Giriş
This guide shows how to replace the A, B, X, and Y action buttons in a Razer Wolverine V3 Pro Wireless Controller. If the buttons are damaged, unresponsive, or worn out, replacement may be necessary. You can also use this guide to install custom buttons if desired.
Important Safety Information:
- Disconnect the controller from the charger, console, or PC before you begin to avoid electrical damage.
Neye ihtiyacın var
Insert the end of a spudger or opening tool in the seam at the top of the controller.
Slide it around the edge to release the retaining clips.
Use the spudger to separate the front and back plastic outer shell of the controller.
Flip the controller so the bottom is facing up.
Use the spudger to separate the plastic covering on the hand grips.
Flip the front of the outer shell toward you. The old buttons should fall out, but if they remain in place, push them out.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Bir başkası bu kılavuzu tamamladı.
