Ana içeriğe geç
Razor A Handle Grips Replacement
Jordyn
Jordyn ve 5 diğer katkıda bulunanlar
En son August 3, 2023 tarihinde güncellendi
15 - 20 dakika
Orta
Öne Çıkan Kılavuzlar
Öne Çıkan Öğrenci Kılavuzu
Do your hands hurt or slip when riding your scooter? Chances are your handle grips need to be replaced. This guide will show you how.
Neye ihtiyacın var
  1. Razor A Handle Grips Replacement, Handle Grips: adım 1, 2 resimden 1. Razor A Handle Grips Replacement, Handle Grips: adım 1, 2 resimden 2.
    • If the scooter does not already have handle grips, skip to step 2.
    • Locate the handle grips at the upper ends of the T-tube.
    • Be careful to keep the scissors away from your other hand while cutting the handle grips.
    • Wedge one end of a pair of scissors between the metal T-tube and a handle grip, with the cutting edge toward the handle grip. Cut the handle grip off.
    • Repeat for the other handle grip.
  2. Razor A Handle Grips Replacement: adım 2, 2 resimden 1. Razor A Handle Grips Replacement: adım 2, 2 resimden 2.
    • Soak the replacement handle grips in warm water for 2-3 minutes.
    • The longer you soak the handle grips in water, the larger they get. Soaking the handle grips for a long time will not damage them.
  3. Razor A Handle Grips Replacement: adım 3, 2 resimden 1. Razor A Handle Grips Replacement: adım 3, 2 resimden 2.
    • Each handle grip should now slide onto the T-tube with ease. If not, soak the handle grip(s) in warm water for another 1-3 minutes.
    • Holding the T-tube with one hand, slide a handle grip completely onto the T-tube.
    • Repeat for the other handle grip if installing both.
    • Let the handle grips dry for 24 hours before use.
Bitiş Çizgisi
Bir başkası bu kılavuzu tamamladı.
Jordyn
544 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 9-13, Amido Fall 2012 Cal Poly, Team 9-13, Amido Fall 2012 üyesi
CPSU-AMIDO-F12S9G13
4 Üyeler
10 adet Kılavuz yazıldı
Bir Yorum
I have found the Razor A5 Lux Scooter the best kick scooter for daily commuting.
Mathew Sam - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 9
Son 30 gün: 24
Her zaman: 5,049
