Ana içeriğe geç
Remove Battery
Neye ihtiyacın var
    1. Remove Battery, Remove screws from bottom of laptop.: adım 1, 2 resimden 1. Remove Battery, Remove screws from bottom of laptop.: adım 1, 2 resimden 2.
      • Flip the computer over to access the screws on the bottom.
      • Remove 8 black, 7mm PH0 screws (M2 x L7).
      • Note: Virtually all the other screws for this computer are PH1 screws which may get stripped when using a smaller screwdriver, but these screws require a Philips PH0 driver.
      FixBot'a Sor
      Yorum Ekle
      • Pry up the clips/latches and then remove the lower case. Start at the front (four clips), then sides (three clips each side) and back (four clips) - there is also one clip in the middle of the case.
      FixBot'a Sor
      Yorum Ekle
    1. Remove Battery, Disconnect battery cable: adım 3, 1 resimden 1.
      • Almost anything that is done with a computer is safer if the battery is disconnected, so it is good to do that now.
      • Disconnect the battery pack cable from the system board using fingernails or a pry bar. Use your fingernails to pull the connector to unplug it. Do not pull the cable. It can be very tight. I used a 3.5 mm flathead screwdriver to carefully push the side plastic edges down towards the battery. Do not knock any of the components on the board.
      FixBot'a Sor
      Yorum Ekle
    1. Remove Battery, Remove battery screws: adım 4, 1 resimden 1.
      • Remove 6 black 4mm PH1 screws (M2 x L4). The lower right screw is close to a magnet that may pull it from where you want it to go - tweezers may be necessary. The Hardware Maintenance Manual does not show the bottom middle screw.
      • Note: Virtually all the screws for this computer are PH1 screws which may get stripped if you use a smaller screwdriver.
      FixBot'a Sor
      Yorum Ekle
      • Lift out the battery.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
johann beda
3.428 İtibar
15 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 26
Her zaman: 137
