Ana içeriğe geç
Remove Lower Case
Neye ihtiyacın var
    1. Remove Lower Case, Remove screws from bottom of laptop.: adım 1, 2 resimden 1. Remove Lower Case, Remove screws from bottom of laptop.: adım 1, 2 resimden 2.
      • Flip the computer over to access the screws on the bottom.
      • Remove 8 black, 7mm PH0 screws (M2 x L7).
      • Note: Virtually all the other screws for this computer are PH1 screws which may get stripped when using a smaller screwdriver, but these screws require a Philips PH0 driver.
      FixBot'a Sor
      Yorum Ekle
      • Pry up the clips/latches and then remove the lower case. Start at the front (four clips), then sides (three clips each side) and back (four clips) - there is also one clip in the middle of the case.
      FixBot'a Sor
      Yorum Ekle
Sonuç
johann beda
3.428 İtibar
15 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 12
Son 30 gün: 19
Her zaman: 123
