Ana içeriğe geç
Remove Stuck Disc from Samsung P241
Neye ihtiyacın var
  1. Remove Stuck Disc from Samsung P241, Top Case: adım 1, 2 resimden 1. Remove Stuck Disc from Samsung P241, Top Case: adım 1, 2 resimden 2.
    • You will need to be near a power source for this guide.
    • With the back of the DVD player facing you, remove the three 1 cm black screws on the right, left, and top sides using a Phillips #1 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  2. Remove Stuck Disc from Samsung P241: adım 2, 2 resimden 1. Remove Stuck Disc from Samsung P241: adım 2, 2 resimden 2.
    • Pull the top cover towards you until you can lift it up and off.
    FixBot'a Sor
    Yorum Ekle
  3. Remove Stuck Disc from Samsung P241, Remove Stuck Disc from Samsung P241: adım 3, 1 resimden 1.
    • After the top cover has been removed, locate the disc drive on the right hand side of the DVD player.
    FixBot'a Sor
    Yorum Ekle
  4. Remove Stuck Disc from Samsung P241: adım 4, 1 resimden 1.
    • Locate the four rectangular holes in the top of the black plastic disc drive.
    FixBot'a Sor
    Yorum Ekle
  5. Remove Stuck Disc from Samsung P241: adım 5, 2 resimden 1. Remove Stuck Disc from Samsung P241: adım 5, 2 resimden 2.
    • You will now pry off the black plastic cover from the disc tray. Insert a flathead screwdriver into the slot indicated and press down while at the same time pulling the screwdriver towards the middle of the device. This will pop the plastic catch out to the side.
    FixBot'a Sor
    Yorum Ekle
  6. Remove Stuck Disc from Samsung P241: adım 6, 1 resimden 1.
    • Without removing the first screwdriver, insert a second one into the hole indicated and do the same motion.
    • You can now lift up the right side of the cover. Don't pull up too far or you could break the clasps on the left side.
    FixBot'a Sor
    Yorum Ekle
  7. Remove Stuck Disc from Samsung P241: adım 7, 1 resimden 1.
    • Now repeat this process, unclipping the catches on the other side.
    FixBot'a Sor
    Yorum Ekle
  8. Remove Stuck Disc from Samsung P241: adım 8, 3 resimden 1. Remove Stuck Disc from Samsung P241: adım 8, 3 resimden 2. Remove Stuck Disc from Samsung P241: adım 8, 3 resimden 3.
    • You can now pop of the black plastic cover and see the exposed disc drive. If there is anything stuck inside that is jamming the drive, you can remove it.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Lawrence Smith
126 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 14-7, Forte Winter 2011 Cal Poly, Team 14-7, Forte Winter 2011 üyesi
CPSU-FORTE-W11S14G7
5 Üyeler
7 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 38
Her zaman: 4,527
