Ana içeriğe geç
Removing Minolta X-370 Bottom Cover
Nick
Nick ve 4 diğer katkıda bulunanlar
En son September 15, 2023 tarihinde güncellendi
15 - 30 dakika
Orta
Öne Çıkan Kılavuzlar
Only requires removing a few screws. No special tools required.
Neye ihtiyacın var
Aletler
  1. Removing Minolta X-370 Bottom Cover, Battery: adım 1, 2 resimden 1. Removing Minolta X-370 Bottom Cover, Battery: adım 1, 2 resimden 2.
    • Flip the camera so that the bottom is facing you.
    • Take a spare coin and unscrew the battery cover off.
  2. Removing Minolta X-370 Bottom Cover: adım 2, 1 resimden 1.
    • Remove the batteries, making sure to note their proper alignment.
    Hi just checking which type of batteries are required? You have two types listed, the SR44/LR44 (I understand those are the same types of batteries) then the CR-1 / 3 /3N 3V battery? How many batteries do I need and which type will I need? thanks!
    Juliette Perry-Dumarquez - Yanıt
  3. Removing Minolta X-370 Bottom Cover, Bottom Cover: adım 3, 2 resimden 1. Removing Minolta X-370 Bottom Cover, Bottom Cover: adım 3, 2 resimden 2.
    • Remove two 4.8mm screws.
    • Remove one 3.4mm screw.
    • Remove one 2.65mm screw.
    • Lift off the back cover.
  4. Removing Minolta X-370 Bottom Cover: adım 4, 1 resimden 1.
    • Remove three 3.5mm screws.
    • Remove two 3.8mm screws.
    • Remove one 6.35mm screw.
    • Remove one 4mm screw. Lift off the disk.
    • Remove one 5.11mm screw.
  5. Removing Minolta X-370 Bottom Cover: adım 5, 1 resimden 1.
    • Lift up the silver, metal piece
    • Please note that some internal pieces may come loose during this process.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Nick
525 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 8-7, Regan Spring 2011 Cal Poly, Team 8-7, Regan Spring 2011 üyesi
CPSU-REGAN-S11S8G7
4 Üyeler
9 adet Kılavuz yazıldı
1Rehber Yorum
good advice, will use, have multiple Minolta cameras to work with.
gabriel johnson - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 47
Her zaman: 11,129
