Ana içeriğe geç
Removing Numerical Keypad
Neye ihtiyacın var
  1. Removing Numerical Keypad, Removing Numerical Keypad: adım 1, 1 resimden 1.
    • You can do this with most keyboards. I had an older Dell keyboard model L100.
    FixBot'a Sor
    Yorum Ekle
  2. Removing Numerical Keypad: adım 2, 1 resimden 1.
    • Turn the keyboard over and you will see 15 screws. Remove them.
    FixBot'a Sor
    Yorum Ekle
  3. Removing Numerical Keypad: adım 3, 1 resimden 1.
    • Take the keyboard apart. You will find a white rubber sheet under the top part of the keyboard. Cut off the part for the numerical keypad.
    FixBot'a Sor
    Yorum Ekle
  4. Removing Numerical Keypad: adım 4, 1 resimden 1.
    • Fasten the top part of the keyboard and take the hacksaw to it. Cut off the numerical keypad part. Do not use power tools because you may produce toxic fumes and even activate fire alarm.
    FixBot'a Sor
    Yorum Ekle
  5. Removing Numerical Keypad: adım 5, 1 resimden 1.
    • On the bottom part of the keyboard, remove the three screws and the metal bar holding the keyboard PCB and fold the plastic sheet so it is out of your way when cutting.
    FixBot'a Sor
    Yorum Ekle
  6. Removing Numerical Keypad: adım 6, 1 resimden 1.
    • Now mark the bottom part of the keyboard for another cut.
    FixBot'a Sor
    Yorum Ekle
  7. Removing Numerical Keypad: adım 7, 1 resimden 1.
    • Cut the bottom part of the keyboard too. Fold or remove the plastic PCB out of the way when cutting.
    FixBot'a Sor
    Yorum Ekle
  8. Removing Numerical Keypad: adım 8, 1 resimden 1.
    • Screw the PCB and the metal bar back on.
    FixBot'a Sor
    Yorum Ekle
  9. Removing Numerical Keypad: adım 9, 1 resimden 1.
    • Assemble the rest of the keyboard, and fold the plastic sheet under your keyboard. Do not cut it because it will render the keyboard useless.
    FixBot'a Sor
    Yorum Ekle
  10. Removing Numerical Keypad: adım 10, 1 resimden 1.
    • Since you have cut the portion of the keyboard with the supporting leg for tilting, supply it with a new leg. You can use a key from the numerical keypad.
    FixBot'a Sor
    Yorum Ekle
  11. Removing Numerical Keypad: adım 11, 1 resimden 1.
    • Tape the key to the keyboad
    FixBot'a Sor
    Yorum Ekle
  12. Removing Numerical Keypad: adım 12, 1 resimden 1.
    • Presto, you are proud owner of a very geeky looking keyboard with even a piece of the PCB sticking out.
    FixBot'a Sor
    Yorum Ekle
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Stanko Vuleta
242 İtibar
1 Kılavuz yazıldı
9Kılavuz Yorumları
this is awful !!
Abdullah Kamran - Yanıt Paylaş
This is awesome !!
What kind of saw and sawblade are you using?
Fixer - Yanıt Paylaş
Manual hacksaw is probably the best choice. Any power tool is liable to burn the plastic and produce fumes which you don't want to be inhaling.
Stanko Vuleta - Yanıt Paylaş
Can i do this to an aluminum extended keyboard usb apple?
appleuserfan - Yanıt Paylaş
Judging by the position of the cable, the pcb is placed away from the numerical keypad, so I would guess you should be able to do it.
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 17
Son 30 gün: 103
Her zaman: 13,589
