Ana içeriğe geç
Removing Solid-State Drive (SSD) shielding
Neye ihtiyacın var
    1. Removing Solid-State Drive (SSD) shielding, Remove screws from bottom of laptop.: adım 1, 2 resimden 1. Removing Solid-State Drive (SSD) shielding, Remove screws from bottom of laptop.: adım 1, 2 resimden 2.
      • Flip the computer over to access the screws on the bottom.
      • Remove 8 black, 7mm PH0 screws (M2 x L7).
      • Note: Virtually all the other screws for this computer are PH1 screws which may get stripped when using a smaller screwdriver, but these screws require a Philips PH0 driver.
      FixBot'a Sor
      Yorum Ekle
      • Pry up the clips/latches and then remove the lower case. Start at the front (four clips), then sides (three clips each side) and back (four clips) - there is also one clip in the middle of the case.
      FixBot'a Sor
      Yorum Ekle
    1. Removing Solid-State Drive (SSD) shielding, Disconnect battery cable: adım 3, 1 resimden 1.
      • Almost anything that is done with a computer is safer if the battery is disconnected, so it is good to do that now.
      • Disconnect the battery pack cable from the system board using fingernails or a pry bar. Use your fingernails to pull the connector to unplug it. Do not pull the cable. It can be very tight. I used a 3.5 mm flathead screwdriver to carefully push the side plastic edges down towards the battery. Do not knock any of the components on the board.
      FixBot'a Sor
      Yorum Ekle
    1. Removing Solid-State Drive (SSD) shielding, Remove the system board mylar: adım 4, 2 resimden 1. Removing Solid-State Drive (SSD) shielding, Remove the system board mylar: adım 4, 2 resimden 2.
      • Remove the system board mylar.
      • Note: Retain the system board mylar and reuse it when reassembling the computer. Replace the system board mylar only if it is damaged.
      FixBot'a Sor
      Yorum Ekle
    1. Removing Solid-State Drive (SSD) shielding, Remove the solid-state drive (SSD) shielding: adım 5, 1 resimden 1.
      • Remove 4 black PH1 screws (M2 x L4) and then remove the SSD shielding.
      • Note: Virtually all the screws for this computer are PH1 screws which may get stripped if you use a smaller screwdriver.
      FixBot'a Sor
      Yorum Ekle
Sonuç
johann beda
3.428 İtibar
15 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 8
Son 30 gün: 27
Her zaman: 120
