Ana içeriğe geç
Removing fans
Neye ihtiyacın var
    1. Removing fans, Remove screws from bottom of laptop.: adım 1, 2 resimden 1. Removing fans, Remove screws from bottom of laptop.: adım 1, 2 resimden 2.
      • Flip the computer over to access the screws on the bottom.
      • Remove 8 black, 7mm PH0 screws (M2 x L7).
      • Note: Virtually all the other screws for this computer are PH1 screws which may get stripped when using a smaller screwdriver, but these screws require a Philips PH0 driver.
      FixBot'a Sor
      Yorum Ekle
      • Pry up the clips/latches and then remove the lower case. Start at the front (four clips), then sides (three clips each side) and back (four clips) - there is also one clip in the middle of the case.
      FixBot'a Sor
      Yorum Ekle
    1. Removing fans, Remove the system board mylar: adım 3, 2 resimden 1. Removing fans, Remove the system board mylar: adım 3, 2 resimden 2.
      • Remove the system board mylar.
      • Note: Retain the system board mylar and reuse it when reassembling the computer. Replace the system board mylar only if it is damaged.
      FixBot'a Sor
      Yorum Ekle
    1. Removing fans, Disconnect tape and cables: adım 4, 1 resimden 1.
      • (1) Peel off the thermal DIMM plate tape from the system board.
      • (2-3) Lift flap and disconnect the I/O board cable from the system board.
      • (2-3) Lift flap and disconnect the audio FPC cable from the system board.
      • (2-3) Lift flap and disconnect the hinge cap lightingbar cable from the system board.
      • Note: my machine did not have the DIMM plate tape or the cable in the upper right.
      FixBot'a Sor
      Yorum Ekle
    2. Removing fans, Disconnect the fan cables: adım 5, 1 resimden 1.
      • Disconnect the three fan cables from the system board by lifting away from board.
      FixBot'a Sor
      Yorum Ekle
    3. Removing fans, Remove screws and fans: adım 6, 1 resimden 1.
      • Remove 7 black 6mm PH1 screws (M2 x L6) holding the fans.
      • Note: Virtually all the screws for this computer are PH1 screws which may get stripped if you use a smaller screwdriver.
      • Remove tape from fans - possibly using gentle heat
      • Remove the fans - be careful of Wi-Fi antenna cables around top left fan and speaker cable around small bottom right fan.
      FixBot'a Sor
      Yorum Ekle
Sonuç
johann beda
3.428 İtibar
15 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 10
Son 30 gün: 33
Her zaman: 134
