Ana içeriğe geç
Removing the Logitech MBJ58 Scroll Wheel from its Mount
Conor Whatley
Conor Whatley ve 5 diğer katkıda bulunanlar
En son December 5, 2022 tarihinde güncellendi
1 - 2 dakika
Kolay
You will learn how to remove scroll wheel from the wheel mount.
Neye ihtiyacın var
Aletler
  1. Removing the Logitech MBJ58 Scroll Wheel from its Mount, Top cover: adım 1, 1 resimden 1.
    • Hold the mouse so that the bottom is facing up.
    • Remove the single Phillips #1 screw from the bottom half of the mouse.
  2. Removing the Logitech MBJ58 Scroll Wheel from its Mount: adım 2, 2 resimden 1. Removing the Logitech MBJ58 Scroll Wheel from its Mount: adım 2, 2 resimden 2.
    • Place the mouse so that the bottom is resting against a hard surface.
    • Lift the top cover of the mouse gently, and remove it.
  3. Removing the Logitech MBJ58 Scroll Wheel from its Mount, Removing the Logitech MBJ58 Mouse Scroll Wheel: adım 3, 3 resimden 1. Removing the Logitech MBJ58 Scroll Wheel from its Mount, Removing the Logitech MBJ58 Mouse Scroll Wheel: adım 3, 3 resimden 2. Removing the Logitech MBJ58 Scroll Wheel from its Mount, Removing the Logitech MBJ58 Mouse Scroll Wheel: adım 3, 3 resimden 3.
    • Locate the scroll wheel on the mouse.
    • Grab the scroll wheel with your thumb and index finger.
    • Gently lift up, to remove the scroll wheel from the mouse.
  4. Removing the Logitech MBJ58 Scroll Wheel from its Mount, Support Spring: adım 4, 2 resimden 1. Removing the Logitech MBJ58 Scroll Wheel from its Mount, Support Spring: adım 4, 2 resimden 2.
    • Locate the spring on the scroll wheel, and carefully remove the spring.
  5. Removing the Logitech MBJ58 Scroll Wheel from its Mount, Attaching the New Spring: adım 5, 2 resimden 1. Removing the Logitech MBJ58 Scroll Wheel from its Mount, Attaching the New Spring: adım 5, 2 resimden 2.
    • Place the replacement spring on the correct side of the wheel (shown in the images) with the prongs pointing down.
  6. Removing the Logitech MBJ58 Scroll Wheel from its Mount, Wheel Mount: adım 6, 3 resimden 1. Removing the Logitech MBJ58 Scroll Wheel from its Mount, Wheel Mount: adım 6, 3 resimden 2. Removing the Logitech MBJ58 Scroll Wheel from its Mount, Wheel Mount: adım 6, 3 resimden 3.
    • Locate the black wheel mount.
    • Note: Make sure that the spring hidden in the mount does not fall out.
    • Separate the wheel from its mount.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Conor Whatley
510 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 5-14, Forte Winter 2013 Cal Poly, Team 5-14, Forte Winter 2013 üyesi
CPSU-FORTE-W13S5G14
5 Üyeler
23 adet Kılavuz yazıldı
2Kılavuz Yorumları
Thank you! The photographs with good resolution and correct lighting made everything clear and comprehencible.
Антон Вакаренко - Yanıt
Very helpful, thank you!
K.S. - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 15
Her zaman: 1,809
