Giriş
Very often problem with this model. In 60% it can be resolved only with reconnecting the Touchscreen flex / ribbon cable.
If this solution not helped you then you must to change your Touchscreen.
Neye ihtiyacın var
Videoya Genel Bakış
Because I can't switch-off the tablet, I'm using the reset button to do this.
Now, remove the back cover.
Open the touchscreen flex cable connector and reconnect the cable.
15 farklı kişi bu kılavuzu tamamladı.
14 Yorum
s'il vous plait vous pouvez m'aider j'ai un problème avec mon Acer B1. problème de démarrage qu'on j'allume il y'a juste Acer qui s'affiche j'ai essayer d'aller en mode recovery (SD IMAGE UPDATE MODE) mais une fois que je clique dessus ça se bloque s'il vous plait besoin de votre aide
If you have a memory card inside, remove it. If you have same problem again, you have a problem with Android OS or a hardware problem.
ZFix -
Great i thought i cannot use my acer anymore, but know its worked thx for the solutions.
It didn't work... I tried rebooting, restarting and taking out the flex cable and putting it back in. Any more suggestions?
Hey!!!!! 6 meses sin usar mi tablet y batallando para corregir el problema y me.encuenteo con ustedes!!!!! Merecen las graciassssssssss thank you colombia
thank you very much... my device is working now.... i'm from PHILIPPINES...
display not open
excelente, arregle mi tablet por tu video, fabuloso!!!
