Ana içeriğe geç
Repairing Mercedes W123 Odometer
Neye ihtiyacın var
  1. Repairing Mercedes W123 Odometer, Repairing Mercedes W123 Odometer: adım 1, 1 resimden 1.
  2. Repairing Mercedes W123 Odometer: adım 2, 1 resimden 1.
    • Get your cluster inside, someplace safe, and on to your work bench. Protect it with something on the bench like a towel to avoid scratching the clear plastic cover.
  3. Repairing Mercedes W123 Odometer: adım 3, 1 resimden 1.
    • To get access to the odometer, the speedometer assembly needs to be removed.
    • First, however, the tachometer/clock assembly needs to be removed as it overlays on top of the speedometer.
  4. Repairing Mercedes W123 Odometer: adım 4, 1 resimden 1.
    • Remove the screws holding the tachometer/clock assembly to the back of the cluster. There are three shown here; a fourth is obscured behind the fixer's hand.
    • You may also need to remove the rheostat that dims the instrument lights.
  5. Repairing Mercedes W123 Odometer: adım 5, 1 resimden 1.
    • You will now be able to carefully lift the tachometer/clock assembly out of the cluster. Set it aside someplace safe. Do not set it face down, on the needles.
  6. Repairing Mercedes W123 Odometer: adım 6, 1 resimden 1.
    • You may need to remove the rheostat that dims the instrument lights first, before removing these last two screws.
    • Next, unscrew the two remaining screws holding the speedometer assembly in place.
    • Note that it shares two screws with the tachometer assembly, on the left hand side, so those are already out.
  7. Repairing Mercedes W123 Odometer: adım 7, 2 resimden 1. Repairing Mercedes W123 Odometer: adım 7, 2 resimden 2.
    • You can now lift the speedometer assembly out, carefully. Note that there are wires that cross behind the gauge face; you will need to clear these wires to remove the gauge.
  8. Repairing Mercedes W123 Odometer: adım 8, 1 resimden 1.
    • Now, remove the single screw that holds the black plug on the back of the speedometer assembly. With the screw removed the plug pulls out of a slot.
  9. Repairing Mercedes W123 Odometer: adım 9, 2 resimden 1. Repairing Mercedes W123 Odometer: adım 9, 2 resimden 2.
    • Now you can remove the two flat head screws that hold the metal back on the speedometer assembly.
  10. Repairing Mercedes W123 Odometer: adım 10, 3 resimden 1. Repairing Mercedes W123 Odometer: adım 10, 3 resimden 2. Repairing Mercedes W123 Odometer: adım 10, 3 resimden 3.
    • Removing the metal cover will expose the odometer. Inspect the various plastic gears for broken parts. If you find any, they will need to be fixed before continuing.
  11. Repairing Mercedes W123 Odometer: adım 11, 1 resimden 1.
    • If all of your odometer gears check out, you can then test the odometer operation to see where the problem lies.
    • To do this you should place a power drill, with an appropriately sized square drill bit, in to the speedometer cable opening and run the drill. Observe the speedometer and odometer function while you do this.
    • View this video to see the test in action. Note this video was recorded after this odometer was fixed via the steps in this guide.
    • If all of the gears on your odometer turn, and the speedometer also moves, but the numbers on your odometer do not turn this is the guide for you! Continue reading.
    so how did you guys manage turn he number with drill ?
    josh - Yanıt
    Josh, we used a drill bit that fit snugly in the opening for the speedometer cable. A square bit works best as it matches the shape of the end of the cable.
    Nicolas Siemsen -
    Hello all. I have a similar problem but with the daily miles counter. He stops everytime @ 29.9 miles and doesn't go further. Is this guide useful then ?
    Kr,
    Bart
    Bart Roelandt - Yanıt
    This would be what I would try first, yes. This is also known as the trip odometer. It is driven off the primary odometer. If the primary is slipping it will also cause the trip odometer to not work properly.
    Nicolas Siemsen -
    Hello Nicolas,
    It's only the trip odometer that causes the problem (sorry for the bad translation - i'm living in Belgium and bought a W123 USA). So what should i do then ? The odometer works fine. So I don't like to open it up when it works fine like it does now...
    Hi I'm from Indonesia can we fix the kmh needle?,, as when I drive under 40kmh the needle bouncing up and down?
    Roy - Yanıt
  12. Repairing Mercedes W123 Odometer: adım 13, 3 resimden 1. Repairing Mercedes W123 Odometer: adım 13, 3 resimden 2. Repairing Mercedes W123 Odometer: adım 13, 3 resimden 3.
    • This brass gear is the item we are interested in. It is attached to a shaft that is responsible for turning the main odometer gear.
    • This grey gear is the main odometer gear that turns the small plastic gears along the top of the odometer numbers.
    • This is the other end of the shaft the brass gear is attached to. It is held in place by a tight fitting brass ring.
    bei mir liegt irgendwo zwischen welle und hauptanteieb, das problem, beide lassen soch einzeln antreiben aber nicht zusammen
    Jonny Wenger - Yanıt
  13. Repairing Mercedes W123 Odometer: adım 14, 1 resimden 1.
    • Now support the speedometer gauge face and the rest of the assembly on something soft that will protect it. Some foam was used in this case.
    • Then, using a hammer and small punch, tap out the shaft shown in the last step from the side with the small brass ring.
    • Press your finger against the gear end to keep the shaft from falling out. This shaft also acts to support the numbers. Without it they "droop" down and can also become out of alignment.
  14. Repairing Mercedes W123 Odometer: adım 15, 1 resimden 1.
    • As soon as the metal shaft with the brass gear becomes loose, chase it out with an appropriately sized drill bit. Go slowly to make sure you don't leave too much space between the shaft and the bit or else one of the numbers might fall out of alignment.
  15. Repairing Mercedes W123 Odometer: adım 16, 1 resimden 1.
    • The shaft should now be fully accessible.
  16. Repairing Mercedes W123 Odometer: adım 17, 1 resimden 1.
    • Inspect the shaft. As you can see here, the area just inside of the brass gear is very shiny compared to the rest of the shaft. It has been worn smooth by years of friction. This is what slips underneath the grey gear, leading to the odometer not turning.
  17. Repairing Mercedes W123 Odometer: adım 18, 2 resimden 1. Repairing Mercedes W123 Odometer: adım 18, 2 resimden 2.
    • You will now want to score the shaft using a utility knife, or other sharp object. The tip of a sharp screw driver can work. Or you can rough it up with thick sandpaper. In any case, the idea is to create a surface that is rough enough to restore friction between the shaft and the grey gear.
    • It isn't easy to take a picture of, but the shaft has been scored in a cross-hatch pattern.
    • You can now re-insert the shaft, chasing the drill bit back out, ensuring that the numbers remain in sync. Once the shaft is all the way back in, you can then use a small punch and a hammer to tap the brass retaining ring back on the end of the shaft. If needed, support the brass gear with a small piece of hard wood.
    When I did this repair, I put a little superglue on the shaft at the place of the grey gear. Just a little, so that the shaft was about 0,2 mm thicker on one side. It never slipped again.
    toon de bie - Yanıt
    Hello,
    I can’t thank you enough for this site. It saved me a lot of money and time.
    Followed your procedure and it works great
    Thanks Paul V
    Paul Vitale - Yanıt
    Hallo, das ist wirklich perfekt beschrieben 👍👍 ich habe soeben nach der Beschreibung meine Kilometeranzeige instandgesetzt. Sehr gut Danke und weiter so 👍
    noki11 - Yanıt
Sonuç
37 farklı kişi bu kılavuzu tamamladı.
Nicolas Siemsen
39.100 İtibar
79 adet Kılavuz yazıldı
Ekip
Master Techs Master Techs üyesi
Community
321 Üyeler
1.468 adet Kılavuz yazıldı
16 Yorum
Hi,
My speedometer needle and odometer don't work when I turn them with a drill bit. What can be the issue? Any guides for fixing?
Thanks
Vito - Yanıt
Hello Vito, as the guide says, what you are looking for is to see if the gears spin on the back of the odometer when using the drill. If the gears spin, but the odometer does not turn, the reason is the shaft being worn as noted. Use this guide to fix it.
If however the gears are not all turning on the back of the odometer it is likely that one of the gears is stripped or broken. You will need to find which gear is broken and replace it. There are sites online that sell replacement plastic gears. You'll need to do some research to find the right one(s). I haven't had to do that before.
Nicolas Siemsen -
Curious, my odometer turned to 161979 but instead of rolling to 161980 it goes back to 161970 and repeats. The trip odometer works fine...any thoughts? I am hopeful it simply starts working again. Thank you!
David - Yanıt
…it’s only my TRIP odometer that stopped working…. I’d bet it’s in the mechanism for resetting it—that is, pushing the button IN to reset the TRIP odometer to 00000….. now jammed at 190.1 or so …. and pushing doesn’t do anything. …
MAIN odometer & speedometer DOEs work as usual. ‘haven’t opened ‘er up and eyeballed it yet. THANKS for the insight here.
…by the way…just in case you’re reading this and had experience with the FUEL gauge also….I specifically can tell you…that stopped working once when I had instrument panel out (for other purposes—as if I brushed against something??)
…it doesn’t work by: being “over” to the right…such that “full” down to about 1/3rd acts normally….but it stops at 1/3rd …
in other words, it could read 1/3rd and be empty. ….
setting trip odometer, thus, becomes quite handy, as I always do…until a few days ago when that stopped working. Peace. Out. 240D 1983 380K 4 speed manual…a beauty mechanically.
83 240D and 300D - Yanıt
What about the aluminium gear beside the odo numbers? Shouldn’t that be fixed to the shaft as well? I have secured the brass gear to the shaft, and the odo is still not turning while the speedo works.
totallyplanecrazy - Yanıt
No, the grey aluminium gear is not affixed to the shaft. It rides on the shaft by friction. The problem that tends to happen is that the shaft that has the brass gear on the end develops a very smooth spot there due to minor slippage over 30+ years and eventually it just slips. That is why this guide describes how to rough up that part of the shaft so it can turn the gear again by friction.
Nicolas Siemsen - Yanıt
So, if I add a key to the grey gear the way I did to the brass gear, it should work as a permanent repair? (If I can figure out how to reinstall everything…)
Nicolas
Many thanks for the very clear guide. It works again, -even the clock!… (I hadn’t read the bit that says disconnect the battery)
Nick
elpho - Yanıt
Hi- great instructions. Thanks. But I am at the last stage and cannot get the speedo cable reattached. Is there some trick.? There’s just so little clearance!
Alexander Westphal - Yanıt
Ok answered my own question. There’s a zip tie in the engine bay which secures the Speedo cable to a bracket. Cut the zip tie and you have plenty of room.
Pls. Specify the diameter and teeth of gears for w123 then I can buy the correct one.
Tks.
Frank
PF V - Yanıt
Where can I get correct Odometer gears for 1984 380SL?
More specifically the small 12 pt gear that fits on the motor shaft and fits over the brass bushing.
James Boyd - Yanıt
Great repair instruction. Thank you!
David Glenister - Yanıt
Eine wirklich toll gemachte Anleitung. Vielen Dank, hat mir sehr geholfen.
Domasch - Yanıt
Buenas tardes. Gracias por compartir sus conocimientos, han ayudado en muchas ocasiones. Tengo una consulta en específico: se consiguen planos para hacer impresiones en 3d de los engranajes? Porque donde vivo es virtualmente imposible conseguir repuestos. Agradezco el tiempo que se toman, gracias por ayudar siempre
Ariel Gonzalez - Yanıt
Is there I need tooth repairs.
As As - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 13
Son 7 gün: 280
Son 30 gün: 497
Her zaman: 39,990
