Ana içeriğe geç
Repairing Vizio Television  Cable Connection
Ricky
Ricky ve 7 diğer katkıda bulunanlar
En son September 15, 2020 tarihinde güncellendi
1 saat
Orta
İşlem Görüntüleri
Daha Fazla Görsel Gerekli
Topluluk-Katkılı Kılavuz
Daha iyi giriş
Having problems with your cable connection? Has replacing the cable failed to fix the problem? You may have a broken connection in your motherboard. This guide will help you repair a broken connection from the cable to the motherboard.
Neye ihtiyacın var
iFixit bu bağlantılar üzerinden satın aldığınızda komisyon kazanır.
  1. Repairing Vizio Television  Cable Connection, Repairing Vizio Television  Cable Connection: adım 1, 1 resimden 1.
    • First, remove the (20) Phillips screws from the back plate. If your television is mounted against a wall, you'll have to remove it from your wall mounting bracket as well.
    • Don't forget the 2 Phillips screws in the motherboard area (circled in red).
    I had a blank screen problem, watch how I fixed my TV https://www.youtube.com/watch?v=keBU2e2S...
    Gus Calabrese - Yanıt
  2. Repairing Vizio Television  Cable Connection: adım 2, 3 resimden 1. Repairing Vizio Television  Cable Connection: adım 2, 3 resimden 2. Repairing Vizio Television  Cable Connection: adım 2, 3 resimden 3.
    • After removing the back plate, you'll see some circuit boards. We'll be focusing on the motherboard to the right.
    • (2) Phillips screws hold down covers over your inputs.
    • Note this screw holds down both covers where they overlap.
    • The bottom cover will not move until the 2 small Phillips screws are removed.
  3. Repairing Vizio Television  Cable Connection: adım 3, 2 resimden 1. Repairing Vizio Television  Cable Connection: adım 3, 2 resimden 2.
    • Once the covers are all removed, you'll see a big hole where the cable connection is supposed to be.
    • Proceed to solder your new connection in like I did here. If you decide to replace the entire part you'll need to remove the motherboard... We'll save that for a different thread.
  4. Repairing Vizio Television  Cable Connection: adım 4, 1 resimden 1.
    • You can then put it all back together once again in reverse order and enjoy some cable TV!
Sonuç
14 farklı kişi bu kılavuzu tamamladı.
Ricky
840 İtibar
3 adet Kılavuz yazıldı
Ekip
TechTucson WeFixThat TechTucson WeFixThat üyesi
Community
2 Üyeler
4 adet Kılavuz yazıldı
6Kılavuz Yorumları
Are there pics of what needs to be done in order to solder the cable connector correctly?
MistaRite145 - Yanıt
how can I order the part to repair the coax connector for the Vizio 32 inch tv
Steven William Schwenn - Yanıt
how can I order the coax connector part to repair my 32 inch. Vizio TV.
WHAT part is the actual connector? Ive searched for days with NO LUCK! Its a rear mount cam twist thing;I can NOT find this part!!!!
john kowalski - Yanıt
My vizio tv is not functioning properly. When i switch it on. The dispaly say. The tuner is not set up. Click Menu so set it up. Then, when i click the “Menu” may lumalabas na “HDTV setting”. When i click it. It will just go back to its normal form.
jpfernandez211 - Yanıt
Where can i find the nearest Service center of Vizio here in the Philippines?
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 47
Her zaman: 17,803
